damiennik
damiennik
Hi
starting to collect and sell watches, I have one that has me stumped , would appreciate any feedback
more questions to follow on what I have.
Attached is a watch that states it is a Cartier, how can I be sure
sorry it would not allow me to upload from my desktop, will try again
regards
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
