Stuck removing striking hammer
Boz
I'm servicing a very dirty striking mantle clock.  It's basic in construction but seems to have survived the ravages of the years very well, though it is totally gummed up.
I cant work out how to remove the striking hammer. I can see no pin holding the hammer on to the arbor so I assume it's pressed on. I've tried using a gear puller but I'm afraid of breaking the pushing-pin. It's almost like it's not designed to be dismantled. Before I start twisting the puller like a gorilla or whacking it with a punch, am I missing something? Maybe heat would help?
    • On the link that I posted, ne of the watches has no crown and another has an a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken,  and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
    • Hello and welcome to the forum.   Enjoy
