@rjenkinsgb might be right. We were all distracted by the false cap on the back while the real opening gap was hiding in plain sight. -
First question is what are the issues you are experiencing and second question is what is leading you to think that the balance is the cause. As far as the pivot goes it looks all there but the photos are not really clear enough to determine much else. Hope this helps to look further into the problems. Thats a confused face right there, pivot which pivot , bottom pivot top pivot choose a pivot, we seem to be having a day of randomness. ??? Bottom of side of pivot ? -
Escapement and balance designs can be good indicators Keyless works ID is the usual method if the movement is within a set time period
