I'm working on a Bulova 11AOCD that has an offset cannon pinion and I need to remove the friction pinion from the arbor.
I was hoping I could use my staking set with one of the roller remover stumps but the wheel is too large to fit into the stump opening.
Any suggestions on how to get the friction pinion off? My first thought is to slip something stiff between the two pinions to create a base and then use a presto style cannon pinion tool to lever it off, but I'm worried I may bend/break something. I have a handful of these movements so if there is a tool specific for this function I may purchase it.
Edited by GuyMontag
Any suggestions on how to get the friction pinion off? My first thought is to slip something stiff between the two pinions to create a base and then use a presto style cannon pinion tool to lever it off. I have a handful of these movements so if there is a tool specific for this function I may purchase it.
Oooooo me me me me me please. I have this memememememe. Apparently i have this tool which is great, Nicklesilver Identified it for me unfortunately they are as rare as rockinghorse dodo. I will post you a picture in after I've made a cuppa. I'm all excited now i thought it would never be seen again.
17 hours ago, HectorLooi said:
I usually just grip the upper pinion in a pin vise, hold the wheel in my left hand and twist and pull it out gently.
I would have thought that the pin vise might damage the pinion leaves, but that gave me confidence to try using my MC cannon pinion remover as I wouldn't think it would use more force than a pin vise. It worked!
Aw sorry mate i forgot all about it. This is the offset cannon pinion remover, bit late now sorry.
No worries 🙂 That looks interesting. Any idea what the tool is called? I guess you would close the "jaws", slip it between the upper/lower pinions and when you squeeze the handle it opens the jaws and separates the pinions? It's hard to tell from the photo but the jaws look like they might be too thick to get between the one I was just working on.
Edited by GuyMontag
According to Nicklesilver that is exactly what it is called. The jaws are actually recessed so a lot thinner than they look. So my curiosity sparked up and i had a measure. A fraction under 0.7mm. I am guessing but i think Nicklesilver is the only other person that has one here. Never heard them mentioned until i was wanting to know what it was.
At least you got it sorted with some good initiative and a sprinkling of bravery . What all good watch repairers endeavour to acquire 👍
My pin vise jaws are made of brass, so it won't hurt the pinion leaves.
BTW, you didn't need to use the #11 blades to raise the height. The plastic tip of the cannon pinion puller can be screwed out adjust the position of the jaws.
I have two of those cannon pinion pullers with slightly different designs but I just tried turning them and neither of them seem to have that feature 😞
If you take a look at your CP pullers, that brown (used to be red) plastic ring on the front, can it be unscrewed? If it can, unscrewing it out would effectively add distance to the height of the jaws. On some big pocket watches, this ring might need to be unscrewed a bit to get enough height to get the CP off the centre wheel.
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
