Here is a lady's pendant watch.  The movement is 16mm diameter.  It is pin-set.  There is a "1" and "2" stamped in the non-dial side, and "362012" stamped on the dial side.  These are the only marks I see.  The dial is enamel.  Hour & minute hands only.  I believe it has a barrel escapement (notch or slot cut into balance staff just under the wheel?).  The case is sterling (marked .935) and stamped with a rampant bear and"331340   5"
The balance staff lower pivots is sheared off, and the top pivot is bent.  Additionally, I believe the pivot jewels are broken also.  These are NOT shock mounted.
I will look for a donor movement if I can find the movement cal./model numbers.  Can you guys help?
Thanks and best regards,
- Tim
Hi and welcome to the forum,  looks like what you have got is a five bar cylinder movement, getting spares is a tough one, You may be able to fine a repairer who can replace the staff tampons (pivots) as they can be removed and replaced a task that requires skill and the correct tooling.  You may be able to Identify the movement through the bestfit books.  They are nice watches non the less.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
watchweasol has put you on the right track regarding the movement. There is nothing in the bestfit books about these movements so don't bother looking. Even if you find what you think is a replacement movement I can tell you the parts are not interchangeable. These movements are Swiss/ French made near the border to both countries.
Hello folks, and thanks for the warm welcome!
Do these ever come up on ebay?  Is there a caliber or references I can be looking for?  Even if I had to replace the entire movement, I'd like to at least keep the dial and case.  And it would be good if the original hands fit whatever movement I wind up with.  I am a learning (beginner) watchmaker, and not without some mechanical skill, but I'm not up to replacing the staff.  Finding a replacement balance wheel assembly would be preferable.
Thanks for the help!
- Tim
Yes you will find them on ebay. No cal or ref as I have already said parts are not interchangeable. It does not have a balance staff it has a cylinder  which watchweasol has already pointed out. Here are a few photos so you can see the difference. A cylinder movement is not a good place to start for a beginner.
Photo 1 Cylinder. Photo 2 Balance staff. Photo 3 Cylinder escapement. Photo 4 Balance staff escapement also called an Anchor escapement.
Edited by oldhippy
Hi Tim  Sterling advice from Old Hippy, these are difficult watches for the professional so as advised not good at all for the beginner. Either take it to a repair shop (which I think would refuse the repair) or put it away and gain the skills required. As mentioned they do turn up on Ebay but parts are not interchangeable. You may strike lucky and find one the same but doubtful,  all the best in your endevour.
I have since changed computers and lost a few former bookmarks in the process, but if I can locate my source again for new cylinders and tampons, I will post the link here.  But you'll need more than just parts.
I use a special set of punches in my staking set, cylinder punches, to adjust or disassemble cylinder staffs.  They were no easier to come by than anything else to do with these kinds of movements.  Old Hippy is wise about this; these are not good practice movements for beginners.  They are most often ebauche movements with few or no markings, varied provenance, and often have parts which were adjusted to fit the individual movement.
That said, by no means are we encouraging you to give up on it.  But we do recommend that it is to soon to begin work on this kind of watch.  There is lots more to learn first.  I have worked on several cylinder escapement watches that other technicians would not touch.  And I learned first hand why they were apprehensive.  These are very different.  Different rules sometimes apply here.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music.     Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero.
    • Good shout - I'll grab something like that and some around the required size from cousins too...
