Ball 1604b
The Yolk is longer then it needs to be and extends into a hole in the plate. the Z shaped thing is held back by a spring.  I'm thinking I'm missing something between the yolk and the Z shaped stop.  Maybe the z thing had a pin in it that was moved by the yolk and has broken off?  What is the Z shaped part called?  Am I missing a part?
The various methods used over the years by manufacturers to stop the movement for hacking are very interesting. This one puts a brake on the sweep seconds wheel directly, rather than the balance. Based on information from the NAWCC forum regarding the Ball hacking version of the 1604, the stopping lever that hits the sweep second wheel when hacked is present in your watch as well as the spring that acts on it, although the spring isn't placed correctly against the outside surface of the lever. If putting things right with the spring causes the watch to be stopped no matter if the stem is pulled or not, then you may be missing the other needed part, which is "An arm underneath the crown wheel [that] is attached to the lever and to an indent in the sliding pinion".
https://mb.nawcc.org/threads/1960s-ball-trainmaster-hacking-a-schild-1604b.182252/
Update. I was able to modify a second clutch lever  and put it on the other side of the clutch.  The stop bar has a broken .40mm pin in it. Removed the old pin now I just need to find a replacement pin long enough to be engaged by the second clutch lever.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
