Pusher stuck - Seiko chronograph 90s
More eloquently put than i Stephen, although i dont think i was too far behind you 🙂. I received an email from Episurf, they dont provide specfic instructions for its application, but did tell me that some watchmakers use a dry rub method and others do not, also in their literature they provide a surface tension measurement of Epilame. -
They don't seem especially clogged not like teeth on a file, maybe a little but a good clean up will certainly improve them. That one in particular is unnamed but still seems fair condition, the others are really good quality, i think the seller was hoping for higher bids. No thats just staining Rich , the surface i would say are pretty even. Probably some discolouration from a metal it was used on. They all bite into spring steel nicely, better than buggering up a toothed file. The brands are from two reputable manufacturers. Thats a really good price . See how the bidding goes. -
Hi, I am in York so we are neighbours.🙂 Thanks for the replies this is a good place to be.🙂
Good evening @oldhippy . Could you use something like greaseproof paper under the iron? -
Thanks watchweasol. Still got to figure out where to buy a suitably sizes syringe that can cope with the glue. Anyone know how syringe needles are sized and where they can be bought?
