Hello again, title says it all. I must be missing something. The date wheel just placed over the canon pinion there is a spring for it. I don’t know if I need too set it on the gear on the wheel or not? Any help would be very much appreciated.
Thanks so much! This can drive a man batty😀 I at least want it well enough so that every time I check the time it doesn’t vex me. Thank you! Now back at it
Hello, when I opened my watch the calendar works consisted of the date wheel, double toothed hour wheel and the date jumper. Does the date jumper need to be set on the hour wheel teeth?
The date wheel is driven by the date driver gear usually with a finger vthat picks up the wheel at change over, the date wheel is usually held by a spring loaded detent to keep it in position untill the nest change.  the site below gives you a good explanation , worth reading.
https://r.search.yahoo.com/_ylt=AwrIQdfMnvpiP3cAxwh3Bwx.;_ylu=Y29sbwMEcG9zAzMEdnRpZAMEc2VjA3Ny/RV=2/RE=1660620621/RO=10/RU=https%3a%2f%2fquillandpad.com%2f2018%2f10%2f06%2fits-a-date-taking-a-closer-look-at-the-most-popular-complication-of-them-all-the-calendar%2f/RK=2/RS=evWRgNxtFa4F7gvf42qx4mWMfCs-
Thanks so much for the help! It led me to figure out the problem, of course the jumper had to be set on the hour wheel gear. How else would it jump😳. Any who, here it is all original 1969 and thanks to your help a perfectly centered date. Glad I joined the forum.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
