So THAT is pinging away
So... got out my lovely Bergeon green mat, cushion, rodico, movement holder, loupe, screwdrivers, Dumont tweezers etc. Feeling like a right proper watchmaker. Can almost hear Nicholas Hacko's voice as I open the yellow screwdriver pouch...
Tackling my first movement - Chinese clone of the Chinese Seagull ST3600-2 clone of the ETA 6497-2. Puffing away with the blower. Dabbing with the rodico. Using the right screwdriver for each head.  Manipulating screws with the #2 Dumont.
First steps - taking apart and reassembling the keyless works. Now I should have used my finger to hold down the yoke spring, but no.. that would not be proper. Fingers? On a watch movement? Perish the thought. Instead I stick a piece of rodico on it to provide mass and hold it down with the component probe (black polyamide one that Mr Hacko says I should get).
And PING it goes. Hear it hit somewhere behind me. A planned afternoon of examining the keyless and motion works ends up with me on the floor with a magnet trying to find a yoke spring that isn't that small but has seemed to simply vanish into thin air.
Just had to laugh at myself. So that is how a part just pings away. Should have used the finger.
I remember one online tutorial that opened with a picture of a watchmaker "smoking expensive Swiss cigarettes and crawling on the floor looking for a part"
At least you only lost one part. My last disaster was a parts tray explosion, and it took a looong time to find everything that went walkies. Eventually I found everything except a crown wheel screw, plus I found three mystery parts!
Have no idea where two of the three extra parts came from.
Sigh.
LOL. So I’m already doing real watchmaking.
I was shocked how that spring just shot away.  I’ve had lock cylinder top pins and springs fly up and scatter and have lost check pin springs from IC lock cores but nothing like that yoke spring. I actually heard it ricochet off something.
Will take extra care with my parts tray. I have had the experience of tipping over an entire lock pinning kit. Trying to sort literally thousands of lock pins, some differing by just 0.015” in length using tweezers and a pin gauge. Needless to say I dumped the lot in a brass recycling pail and bought new refill packs of pins.
Got the ST3600 with the expectation that I would break a few things as I practice on it but honestly didn’t think I would be crawling on the floor so soon.
Haven't found the yoke spring yet. Had ordered a pack of assorted shepherd springs from Cousins so maybe I can subsitute one of them when the order finally leaves UPS purgatory, returns to Cousins, then to me.
Didn't clean or oil anything. Only manipulated the various parts, learning the different screw types, and how each wheel is oriented in its jewel, how they fit together and spin.  Pretty easy to identify each part, even each screw type.
Just put it together, sans yoke spring. Getting the setting lever back on its screw took a few attempts. Learned that two hands are necessary when putting bridges back on. Was anxious about damaging the balance but it slipped right in and sprung to life when the bridge was nudged into place.
Seeing that balance wheel spring to life was quite a thrill!
Edited by JohnFrum
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
