Thinning spring & coiling
This guy is impressive.
Recently (and I posted about it), I was faced with a 400-day suspension spring that was too thick.  The clock ran fast.  Rather than order another of the correct size, I used sandpaper folded over the spring.  I ran the folded sandpaper up and down repeatedly.  This worked wonderfully well to calibrate the rate of the clock.
But, the work in this video is many pay-grades above my little effort!
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly filed the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
    • You can try a rubber on that the sort for rubbing out a pencil.
    • Determined that the nos staffs are the correct length for the movement by fitting the just the staff and i should be able to find a wheel and hairspring to fit. Problem is the roller hole is too large.
