My first attempt! AS 676
Completely new to watch repair, shiny new tools in hand and impatiently waiting for a Unitas 6431/6445 to arrive in the post to begin to learn on, I decided to take a stab at disassembling and reassembling an old watch that was passed down to me, nothing sentimental, was just floating around with some unknown jewellery.
With a bit of research I've found it's an Australian designed 9ct Hantily case with an AS 676 handwound movement. After researching Hantily, I've discovered that they were producing cases in a factory in Richmond barely a kilometer from where I live. The spelling of the logo (business changed several times) and the Ebauche SA TR shield stamp makes me believe it dates to between 1926–1934.
I was too nervous to try and clean it properly, but I successfully managed to fully strip and reassemble the movement, set the time and recase it. The tiny movement size of 8.75''' blew my mind at how delicate things were. Several screws barely turned with my 0.80mm screwdriver, and I also had to drill a hole in my new loupe...
While probably a stupid first undertaking at least now the pocket watch is going to seem huge in comparison!
Well done Hutch with your first attempt, you didnt mention if it ticked away after your reassembly. If so then very well done 👏. Some good research that you have done as well. I believe both repair and watch company history go hand in hand. So anyway how is Starsky ? Lol.  My absolute all time favourite American tv show. 👍
Thanks! and yes it ticked away, can tell it's got a low amplitude from 100 year old grease etc so it needs a proper clean. But my learner movement arrived so I can't start practicing now
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
