ETA 2898-2 Documentation?
A friend asked me whether I could service his Revue Thommen „Triple Date Moon Phase“. It was built in the ’90s and should a have a caliber ETA 2898-2. Can somebody in this friendly forum help me with a documentation of the dial side? I cann‘t find anything in the net (except these photos).
Edited by Kalanag
52 minutes ago, Kalanag said:
.Can somebody in this friendly forum help me with a documentation of the dial side?
The "dial side" is a separate complication module not made by ETA but by Dubois Dépraz, which doesn't release any documentation or parts. You can find an article and video at https://www.thenakedwatchmaker.com/decon-dubois-depraz-full-calendar
  • Thanks 2
Great info and perfect pictures! Thank you so much! That‘s more than I dared to expect!
I like to have an idea of what to find inside before I open a valuable watch.
That was a very nice website link by the way
in addition to sources like that for the chronograph module sometimes the companies that are using the module I've seen that they have servicing information. I was looking at something the other day going through a series of documents and I saw chronograph module just can't quite remember which one was in.
Then a course there is the problem of even with the documentation And pretty pictures getting spare parts Will probably be an issue
The watch arrived today. This beautyful timepiece has been serviced from time to time by a professional watchmaker who closed his business some years ago.
The case needs a new gold plating. My plan is to remove the movement and the crystals and give the case to a professional goldsmith nearby. He said he can do the cleaning, polishing and plating.
I‘m going to service the movement and will report here soon.
The journey begins!
The timegrapher shows a decent amplitude, zero beat error and a significant time loss.
I found the seconds hand loose and - as a result - circular marks on the inside of the front crystal
The obvious reason for the loose seconds hand was a minutes hand not pressed deep enough onto its pinion preventing the seconds hand tube reaching its deep sitting pivot.
When inspecting the case the first question to my fellows here came up: How to deal with these tiny pushers. Must they be pressed out before replating the case? If yes, to which side? Thanks for any help!
Edited by Kalanag
I would like to report that removing the triple-date-moon-phase module from the ETA 2892-2 was more than easy without the necessity of any disassembling on the module. It is held by the dial feet screws of the ETA’s main plate and can just be lift off (The dial is tightened to the module by two other screws).
Edited by Kalanag
I forgot to mention that the date module seems not to be made by Dubois-Depraz. The quality standard is lower and the month can only be changed with the pusher by hand. There is no manufacturer logo stamped on the plate
Edited by Kalanag
To finalize this thread I like to report that I successfully serviced the movement. I used the old pushers in the newly gold plated case. The plating was done by a goldsmith after I had removed the crystals, the crown tube and the pushers. The crown and the front crystal are new. My friend is happy wearing a good looking watch again 😀
Edited by Kalanag
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
