Hello from North Yorkshire
Hello people - I'm Nick and I live in North Yorkshire. I've always had an interest in timekeeping and horology but never as a hobbyist or as an enthusiast. I started a very small collection of pocket watches (American Elgin & Waltham) earlier in the year and also a small collection of mantel clocks, primarily Smiths. I've taken the plunge into basic repair/mantenance of the mantel clocks as I don't have the equipment to mess around with the tiny components in pocket watches.
I've been lurking on the forums for a few months and have gleaned a lof of fascinating and useful information from forum members.
Very keen to learn new skills to enable me to repair/restore my growing collection of clocks.
Many thanks for the welcomes 😊.
I've got 4 Smiths mantel clocks and 3 pocket watches. A small collection but have only just taken the plunge with collecting at the beginning of the year after losing my dad.
Here's some photos with basic info of what I currently own 😊
Photo 1 - Smiths Guildford 8 day Westminster floating balance, about 1962. My best runner.
Photo 2 - Smiths 8 day strike (forgot the name), pendulum, about 1952 ish. Runs really well.
Photo 3 - Smiths 8 day Westminster, mid to late 1950s. Works fine except the chimes are currently well out of sync.
Photo 4 - Smiths Lisbon floating balance 8 day Westminster, early 1960s. Runs too fast and chimes/strikes erratic (one to fix with a donor floating balance unit currently in the post)
Photo 5 - 1932 Waltham 16s full hunter in Dennison case & 17j P.S Bartlett grade 1908 movement. Excellent runner.
Photo 6 - 1897 Waltham 16s grade 1888 open face with 7j. Runs but stops; think it just needs a clean and service, the balance looks good.
Photo 7 - 1919 Elgin grade 463 open face 3/0S 7j. Fantastic little runner.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
