Omega 620
grsnovi
I purchased this movement some weeks ago and it wants to run. I haven't yet done anything with it because I keep fouling things up with washing the balance and destroying the hairsprings. I'm also still shooting screws all over the place but the new tweezers I got seem to be better (or maybe it's just me)? Anyway, I also got a macro filter to get me somewhat closer than my 100M28 macro lens. This is a focus merge stack of 12 exposures. I see some distortion around the text on the bridge and wonder if instead of 12 shots if I had made smaller focus adjustments and merged 48 instead. Will need to experiment. Also (as noted elsewhere) I pulled the trigger on a trinocular AmScope 7x - 45x boom stand microscope. The scope ought to allow me to drop one of my cameras into the third tube.
13 minutes ago, Kalanag said:
Well done! I like this shot!
Thanks, it was really just a quick excuse to try the Raynox 250 (that arrived today) on the 100M28. What I really need is a ring light. While the 100M28 allows me significantly more room between the fully extended lens and the subject, I have only been using a rectangular array of 160 LED's mounted on a small tripod - certainly not optimum.
The other thing that I always forget is to clean my subject. There have been shots that I've meticulously "spotted" in post but this is just too dusty. I should have cleaned it.
8 hours ago, grsnovi said:
…I'm also still shooting screws all over the place but the new tweezers I got seem to be better (or maybe it's just me)?…
The most important thing is practise. One has to learn controlling the force applied by the fingers. Better to drop a screw than to shoot it away. I grip the screws on the threads only to be safe.
Edited by Kalanag
9 hours ago, Nucejoe said:
What is wrong with lifting a screw with rodico. Not illegal is it?
I used to do it all the time when i started, i just prefer bent tweezers now for practice.  Occasionally some rodico would get stuck in the screw slot but thats no great shake is it, unless the watch repair police get wind of it.
You just need to address and dress the inside of your tweezers G. And dont grip the screw so hard, it opens up the very tip of your tweezer and pings the screw away.
You wont lose it so easy that way. I do prefer the screw head tbh, it helps me position the screw better. I can orientate the screw to vertical that way by nudging the side of the movement or the movement holder with the screw thread and then drop the screw straight in the hole. I find bent tweezers really nice to use for this. But we are all different its whatever works for each of us. Different methods to achieve the same result, i cant change the way i do things if i wanted to. Been using tools since i was 3 and everyday almost for the last 40 years.
On 6/15/2022 at 5:10 AM, anilv said:
Good tweezers really make a difference. Cheap ones have too much tension so you have to use too much pressure and loose sensitivity.
Anilv
This is very true anilv. I adjusted a couple of cheap ones when I started repairing. Spent a good hour taking the thickness out of the back ends of them. Made a big difference to the feel, but then acquired a couple of full sets of Dumont and a few others from a job lot sale. These are far superior to the cheapos that I was using.
2 hours ago, grsnovi said:
I can't blame the tools. The ones I have are Dumont, Bergeon and Horotec.
I'm going to say: "It has to be me"
It probably is you G, but you just need to practice mate. Don't let it bother you, you will get better honestly. What specifically are you having trouble with ? Pin down the exact issue then work on that. I've strength trained for 15 years and did body building and martial arts on and off during that time.  Researched and studied endlessly how muscle fibres, tendons and ligaments all work in synergy. Understand how our motor skills adapt and learn to cope and compensate for different situations. That process is less adaptive as we get older we have to accept that that is a part of aging. But I've trained with men and women in their mid seventies and it blows my mind what they were capable of, age is just a number, accept that number is never going to go backwards but  not that it is going to hold you back. Believe that you can do much more than you think you can. Just practice G everyday with a good pair of tweezers, choose the set you are most comfortable with now and stick to that set, don't chop and change because that will disrupt your fine motor skills learning. Our motor learning takes on a similar path to our muscle memory ( we never forget to ride a bike, bit rusty to start with but we quickly improve ). It takes around 300 repetitions to get a form down, if those repetitions are of a crap form because they were rushed or we weren't concentrating on making them good to start with then we've got stuck with a bad habit. It then takes another approx 5000 repetitions to correct that form and make it work the way we want it to. Basically to save a shit load of time get it right first time. This applies massively to bodybuilding as an extreme of our physical abilities but it also applies right down to our finest motor skills. I think what you might be experiencing G is the bad habit of gripping your tweezers too hard in an attempt not to drop anything, unfortunately this has the effect of pinging tiny parts away. Do what I suggested a little while ago, slightly roughen the inside surface of your tweezers to give them a little surface friction, ask me what or how to use or do it if you are unsure. Then just practice everyday for half an hour picking up different sized screws, twist and turn your tweezers while holding the screw adjusting your grip to stop you dropping the screw. Keep your touch very light, never overgripping as this will pull you back into that bad habit that you are trying to get out of, it's far better to drop the screw in front of you than it is to ping it off into oblivion . It will take a little time G so don't get frustrated if it isn't working overnight but it will come and you will become really good at holding screws and springs etc without dropping them or shooting them off. 😊😊
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
