Seiko 6309.
Hello. Here I am again.
I have disassembled a 6309. Lost a part. Setting lever axle, 'ping' and it was gone. New one ordered.
Whilst waiting, I decided to clean the case. Done. Looks ok. However crystal is Cracked and I will order a replacement. I've removed it from the case, but cans see the inner ring. Can anyone tell me how to remove it please, or at least point me to the correct video.
Regards
Ross
Edited by rossjackson01
added photographs
The replacement crystal will have its own ring (asuming you've ordered a tension ring crystal of course), no need to take this one out. If you want it for whatever reason, some get out easily prying it carefully, or deforming the plastic slightly,
Aah! wasn't aware. I don't have the knowledge yet. Just obtained it from you though. Good man. I've made a note in the parts box for ordering later. Thank you.
Regards
Ross
33 minutes ago, mikepilk said:
If you want to order a generic one, instead of the Seiko original, you can get the "Tension Ring" watch glasses here (with either silver or gold tension rings) : https://www.cousinsuk.com/category/tension-ring-armoured-watch-glasses
Brilliant. Not ordered yet, but I have made a note of the part number ready for when I do. Thank you.
Regards
Ross
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
