Hello!
I have a 5856 that is losing time. I opened it to see if i could adjust it slightly, but i cant figure out which screw to turn, or if it is even possible on this movement. Can someone maybe point me to the right screw or tell me if i am wasting my time?
It probably needs a clean and lube. Check this for more info.
On 2/5/2021 at 3:22 AM, mzinski said:
Does anyone have a King Seiko Caliber 5856 service manual? Or one for a similar reference?
I have a King Seiko I'd like to clean up but I'm hesitant without a technical document.
Thanks!
This is the only screw with which you might be able to fine tune the timing. It‘s a trim capacitor:
Edited by Kalanag
Excellent! thanks alot! do you by any chance know if + is clock wise or counter clock wise?
Absolut beginner here i might add, thank you for your patience!
Edited by jpg
Mark or photograph the current position and then try. These trim capacitors typically can be rotated all way round and have one position for maximum capacitance. Either way you go from there will reduce the capacitance and speed up the watch.
Edited by Kalanag
1 hour ago, jpg said:
Hello!
This will regulate the timing. Servicing it will also help, the rotors can get quite clogged up with wear debris. The train wheels are very tiny so be careful, also the rotor can be a real shite to place back with being magnetic. They want to stick to everything and jump around. There is a little trick that helps with that though.
And what little trick might that be?
If i told you I'd  have to silence you lol
Seriously if you decide to strip down and service the movement i can talk you through it .
All of this is based on my hobbyist experience.  Seiko quartz of this era came pretty highly regulated.  They were designed in the mechanical watch era, with mechanical watch parts, and were meant to be serviced.  If it is loosing that much time, it needs a service.  I have serviced a few 754x movements that were loosing significant time.  Without adjusting the trimmer, they all came up keeping time within seconds a month after servicing.
I would not touch that trimmer screw until you have serviced it.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
