Spitfire flyover
Top one is a Spitfire. I just watched a YT video on those last night. I didn't realize that they went from the mk1 all the way up to the mk24 (although every variation wasn't built or flown). Most had the same airframe. One variation had the wingtips chopped off. The later variations had much higher HP Rolls engines.
I think the lower one is a Hurricane.
Two super marine spitfires take to the skies over south and  east Uk. I was lucky enough to be directly below.
The spitfire is the one on the left. You can tell by its wing shape.
I met an ex-Spitfire pilot in Darwin many years ago.
If I remember correctly, he said that the Hurricane was far more manouverable, but could not match the Spitfire for outright speed.
Was fascinating to talk to him.
Edited by Michael1962
Apparently there were more than 22,000 Spitfires produced v. approx. 14,400 Hurricanes.
In the YT that I watched last night it said that they chopped the wingtips off some of the mk.V versions to make the Spitfire able to roll easier and be more maneuverable.
They started out with 1030 hp Rolls-Royce Merlin III engines in the mk.1 (1938) and finished up with 2120 hp Rolls-Royce Griffon 85 engines in the mk.24 (1947).
Actually Rich yes you were correct a spitfire and a hurricane, for some reason a change was made to the aircraft choice.
22,000 spitfires manufactured only 54 left in existence. Around 2-4 million depending on its condition if you fancy one. 50,000 a year to maintain it and 30,000 for your insurance to fly it.
I managed to get a better photo while i was flying alongside wearing my cape,spandex outfit and boots
Edited by Neverenoughwatches
  • Haha 2
How do you keep warm at altitude? I found spandex to be a little thin above 1000ft. I seldom go above that now that I'm a little older
Edited by gbyleveldt
  • Haha 2
Those were among the survivors flown by brave guys who were a lot younger than us.
7 hours ago, oldhippy said:
How about this.
That's a beautiful case back on that IWC. My IWC Mark XV Spitfire doesn't have that on the case back. I believe they increment the Mark designation each time they do a release and the watch is popular (likely since it is relatively affordable). The movement is surrounded by an iron ring which (they say) will prevent the movement from becoming magnetized due to the high RPM's of the engine that the pilot was sitting behind.
8 hours ago, Neverenoughwatches said:
Erm have you seen the environment when I'm at home. Current address Fortress of Solitude.
Lol. It was my daughter's idea, when she was a little girl she used to say "daddy you can do anything cant you", she's now 28 and still says "dad you can do anything" bless her ❤
I was getting the blurb on these mailed to me. For some reason, I think they said that they were going to be able to use metal from a Spitfire to make these watches.
Though that might be something I made up after too many hours of internet looking at YT videos and browsing forums and looking at ebay to find watches that I wanted to buy and little sleep.
That happens 😅 good idea though. I would want some evidence before i bought one though.
Just in case anyone thought i was kidding about my current address 😅. Its actually my postal address
Btw the S isn't an S. Its the family EL symbol . It stands for HOPE. My daughter is my Supergirl i tell her she can do so much more than me. X
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
