Just stripped down a William and Gilbert 1886 mantle clock, my first American clock for cleaning and by gosh does it need cleaning not come across one this dirty before ,though i dare say a lot of you have and worse.
Anyway my question is how to get the arbor out, the count wheel is riveted to the barrel, on both arbors the rachet wheel won't budge don't want to force anything in case i damage something and just hope the barrels will go on my springwinder ok. Thanks everyone
This is a new one on me. I would think the ratchet wheel is on a square. Is the count wheel riveted on to the barrel or pressed on? Until you remove the ratchet wheel it is hard to tell.
Yes the ratchet looks like its on a square but won't pull off and i don't want to force it in case i damage something, and the count wheel is riveted on will give it a good clean and have another look.
I am going to give it a clean and try the brute strength method🤣
54 minutes ago, oldhippy said:
I'm sure if you put a couple of good man enough screwdrivers under the ratchet wheel it will come off. What a crazy design.
Yippee😂 finally got the arbor out and ratchet off after someone surgested supporting ratchet and giving the arbor a few taps, well after a few whacks rachet popped off and arbor came out job done seems like alot haven't seen this type before even are friends across the pond thanks everyone for your input
37 minutes ago, oldhippy said:
That is good news. What are you going to clean it with?
I have gave a first wash in warm water and liquid to get some of the oil off yesterday and now i have the mainspring out i will do the same with the barrel etc accept the spring then everything in parrafin then final wash.
Hi just some advice not about this clock but one i am thinking of buying. Didn't want to start a new thread for this,i am told it's German but that's all they know about the clock except their father had it for 38 years. Any Thoughts.
With out seeing the movement I can't really say. Its a strike, that top doesn't look right it looks more like the sort of thing you see on those German wall clocks which many confuse them with the proper Vienna wall clocks. Take that off and the case looks right.
Here is an example of the type of German wall clock.
Thanks for that oldhippy did ask them if she knew the makers name or if there was a trade mark on the movement all she knew was her father had it for 38 years and it's been stored away for a few years so she is having a clear out, thanks anyway Hi watchweasol that's it no photo of the movement she only wants £20 for it but then i have to pick it up from Leyland so i will probably give it amiss, thanks anyway
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
