After destroying the Elgin 313 balance and not having any luck combining the other parts from the two movements, I put that aside and was going to re-assemble the Buren 410 Grand Prix. Unfortunately the setting lever gave up the ghost. I've seen other movements for quite a bit and I believe that I've actually found single piece parts (for what I paid for this whole movement).
I guess I'll set this aside as well. Maybe I'll see some 410 movements at reasonable prices?
Next up I guess will be the Omega 620. Last time I touched it, it looked like the balance wanted to go - maybe there's hope for that one?
This shot was taken with the 100M28. I also took several with the same lens with 21mm of extension tubes installed but this was overall a better image.
11 hours ago, grsnovi said:
After destroying the Elgin 313 balance and not having any luck combining the other parts from the two movements, I put that aside…
These are the unevitable setbacks and frustrating moments on the long way to mastery. I learned that especially in watchmaking you cann‘t imagine what can go wrong before it has gone wrong. I would wait with the Omega…
Edited by Kalanag
Horological terminology can always be interesting because in different parts of the world parts may have a slightly different meaning. But I'm pretty sure that the part you have a picture of is not a setting lever. I would probably go with the term set bridge it does by the way cross reference with some other movements I have a link . Then it looks like it might actually be in stock.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=X`_D_J
http://www.julesborel.com/s.nl/it.A/id.58111/.f
I have a Buren Grand Prix with exactly the same issue.
That is probably wise advise! I still have a smaller Elgin grade I haven't opened as well as the Pobeda Zim that hasn't yet arrived.
10 hours ago, Nucejoe said:
Have you shown all the pieces?
Ahh, having just visited Dr. Ranfft's site I see what you mean. My dial side looks different in the keyless area. In fact, I looked at all of the 10.5 manuals and I didn't see anything close. Just attached a shot of he keyless works prior to cleaning.
Defect in the design or the material possibly.
Edited by grsnovi
visited Ranfft and noticed dial side differences, added dial side shot and shot of keyless prior to cleaning
In watch repair the classic way to figure out a mystery movement is if you know the diameter the main plate so you have the size you go to the fingerprint system of the bestfit book. Then you can look at the setting parts because they're all unique and see if you can find your setting parts and then you know what your mystery movement is.
Your movement for instance is not a 410 as they setting components do not match at all which you've already confirmed so this brings up the problem of why do you think it is a 410?
I snipped out an image and? I'm not finding much information on the 195 or any parts at least one normally looking
I don't remember why I thought it was a 410. It might have been based on a cursory scan of Ranfft based on the 10.5 size and the fact that the train side of the 410 closely resembles the one I have.
It certainly looks like the 195 based on the above image. Ranfft doesn't show a 195.
Edited by grsnovi
