Watched Marks video on hairspring repair again today in prep to trying it myself on a scrap movement. Needless to say, for a first attempt it didn't go totally to plan. Twist reduced but now have a few "waves" in the outer coil.
Replacement would be the answer but being a vintage movement spares could be difficult to source, e.g. obsolete part number.
In a similar way to Marks explanation on mainsprings, are there any standards for hairsprings to aid sourcing at a materials house? Or is it by reference to movement calibre only?
Thanks.
Thanks.
I'm sure it it will be by make and calibre.
Getting the correct hairspring is very difficult. You need to know its length, strength and also you need the correct t centre stud.
I have accumulated lots of hairsprings over the years from eBay but it's amazing I never seem to have the correct replacement when needed. Here is a good explanation I copied from the web a few years ago
First is the diameter of the hairspring. It should be roughly half the diameter of the balance wheel.
Next is number of coils.
The correct hairspring mating to the balance wheel should hang approx. 1/2 inch.
So, you take the tail end of hairspring and make a small hook and hold up hairspring by centre coil and gauge the distance of how far down the hairspring stretches when the balance is hooked on.
Considering all of the above, you might be able to order the correct spring if you still have the old one. You could compare the diameter and number of coils.
Once you pass the 1/2 hanging test, you then cut out small section of inner coil so to bend in to fit the hairspring collet. Try to make cut and bend place collet in centre.
Then you vibrate the hairspring by holding it up at locations of the end coil till you get the balance to turn back and forth pretty close to a similar watch balance. There are a few different methods and tools to vibrate hairsprings and you don't have to spend big money.
The point on the hairspring where you hold it, that makes the balance turn in same speed, is the spot where the spring will be at the regulator. So you don't cut there, you leave some slack so you can stake it.
The vibrating part I just use a watch with a second hand and count the vibs.
Below is the only company I have found that sells new springs BUT they are incredibly slow. The majority of springs sold are without the centre collet.
http://www.britishprecisionsprings.co.uk/index.html
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
