ESA 9158 NOS case for balance complete
Do I detect a worn/scuff ring on the inside of the case back. If so then at some stage in its life the rotor have been rubbing on the inside of the case.
Hi everyone, i'm currently having a problem in algnment of the 7s26a hairpsring, it causing +13 rate when it comes to crown down possition. What should i do, what would be the technique for having it good. Hope to know any idea of how to do it right. Thanks.
🤔 the crystal doesn't have to fit onto a detachable bezel, it can be pressed into the front of the case. Very curious as to why there is a threaded ring inside though. I do have a record www that i could pull the movement out of but I'm away in just over an hour.
