Identifying older Citizen Quartz watches
MF60
Hello all,
I was successful in restating two older watches that I had set aside.  I bought new batteries a week ago and they both restarted.
I admit to having left the old batteries in them (I know better now).
a little background -
I liked this model because the appearance was nice, it was water resistant and the best was the overall thickness was about 8 mm.  It was nice to wear with the stretch band and lasted a long time. I never changed the pattery myself but always took it to JC Penney where I bought it and either dropped it off and walked around the mall or came back a day or two later.
Eventually the repair guy at JC Penney told me he could not fix it (I did not remember the symptoms) and I bought another and always had him change the batteries.  Eventually in 2017 bought an Apple Watch and never wore the second Citizen watch.  But I kept them.
So now both are working but I do not understand the age of each watch.  I downloaded the Citizen Watch app and it's not finding the watches using their app.  Maybe I'm not the only one with the problem:
https://support.citizenwatch.com/hc/en-us/articles/360015206713-Why-doesn-t-the-Citizen-app-recognize-my-watch-
I think I am reading the case backs correctly and one is s/n 590888 and the other s/n 967716.
I see this as they are both caliber number 5500 for each watch.
Is the difference only the case number, and how would I know the model number of each watch?
While both work, the one I think is older (590888) has more problems the crown is difficult to turn and and I can't easily feel the two clicks when pulling out the stem, and the gasket is deformed.  It's almost impossible to get the date and day set.
The time onn both watches over time match very closely to the time I set them to on my desktop PC.
Many thanks in advance for suggestions on getting part number list and maybe a manual or instruction guide.
Mark
Usually for both Seiko and citizen the movement number is on the case back. It's usually the Four digit number with the – in another four digits or some other numbers then there's the serial number that is subject to interpretation but there's websites out there that people will tell you how to do that.
Problem with vintage watches especially a quartz watch is the gaskets will disintegrate with time. Disintegrating gaskets allow bad things into the watch. Is a common belief that quartz watches run forever and never need to be serviced so they're less likely to ever get serviced versus the mechanical watch.
4 hours ago, watchweasol said:
Hi fid attached the tech sheet for the citizen  also contains the user instructions. Hope you find it useful.  Decoding the serial numbers is a bit vague.
This is great.  Everything I would need.  It looks like I will have to open it up and read the number off the case to figure out the model number.  Its not surprising that the Citizen Watch app in the Apple Store was not able to find the watch.  But now I can possible figue our why there are problems withsetting the DAY on the older watch (590888). I can sent the time and the Calendar Date but not the day. It's set to "MAR" which is the abbreviation for TUE or Tuesday, but in French.  Not sure what other languages use "MAR" and the abrreviation for Tuesday
I appreciate getting the PDF.
Mark
Thanks JohnR725.  I was pretty surprised to see the condition of the gasket.  Fortunatly I've kept it is a dry environment.  If I can find a gasket I look forward cleaning the cast and back and installing the new gasket.  I suppose since I have the technical manual I could inspect it a little further and possible figure out why the mechanism is so stiff.
Mark
Mark
Depending upon the model there are several gaskets. The classic back gasket that were all familiar with. Sometimes the crystals held in with the gasket and that can get brittle with time. Or even the glues they use can break down with time. That's where he go to wash the case you might be surprised with the crystal falling out which strangely enough happen to me the other day the glues had just disintegrated. Then one of the problems a lot of times for setting would be the crown gasket auto times for citizen and Seiko it's easy to get the crown gasket off and replace that. You won't know until you get the movement out of the case whether it's a casing problem causing your setting issues or a movement problem
    • Er yeah, not quite sure how to respond to that one Mark 😅. But yes i fully appreciate what you have done here today. I look at it like this, i dont know if you have children Mark,  i have a son and a daughter both around 30 years old but still my babies. I remind them every couple of months, " if something happens to me, i get run over by a bus, i have a heart attack while out running, I eat a very dodgy burger, you know where the spare hidden house keys are dont you, you know where the stashes of money are don't you, you know the things i have that are valuable don't you, you know how to deal with my finances don't you, you know the value of my watchroom and where the value lists of all the tools and watch collections i have are dont you, dont mess it up and dont get ripped off i want you to be rich when I'm gone "  This forum is your baby Mark, i dont think i need to say any more. Appreciate your time Mark, live long and prosper matey 🖖 Oh my flipping god, who's old enough to remember when the Iron lady came to power, i remember the old bag took my morning milk away from me. So I'm only going to ask you this once Rich  " where is Ross and where is Nucejoe and what have you done with them " Ross my allstar and Nucejoe one of my wingmen, i aint happy Rich not happy at all.
    • Thanks Richard - Send me a PM - we shall discuss and get you set up 👍
    • It's a good point, we really love the forum and are scared of losing it. @Mark do you mind if we exchange contact details?  What happens if you don't wake up in the morning? Hopefully not but @Neverenoughwatches is correct, who knows. Could the site be passed on to someone else? It would be a  travesty to loose contact with each other and also so much information.  Please note, the question arised because we care so much.  We wish that you will live for ever but none of us will.  Beat me too it.
    • As long as it’s legal and not spamming, information shared in private messaging between two consenting members is no concern of mine matey 👍 this isn’t eBay 🤣
