Balance Holder Tool
HectorLooi
4 minutes ago, Tiny said:
So is it ok to just place it in a tray until it's time to fit it back into the watch.
Ā
Ā
Ok. This is me with a balance . I take it out of the watch, I look at it to see if it's doin ok.Ā  I carefully flip the cockĀ  over onto it's back. Tbh. I don't really have to think about being careful anymore.I have it down to a fine art but I'm still gentle . As you flip the cock over make sure the balance wheel goes with it, 2 tweezers if you have to. Cock is on its back the balance staff is sitting nicely in the jewel hole. I put it in a low tub of naphtha, I leave it for 15 mins, I then agitate the naptha over it, lifting the wheel if necessary to get it into the coils. When it looks clean, I lift it out onto watch paper I use a blower on it, I lift the wheel up again while using a blower on it to help it dry. When it's dry I put a glass over it to protect it from dust. It's now ready to go back into the watch first to check the beat error, then adjusted if needed then back under the glass until start up. Job done, that's how I do it and will always do it unless i need to change it because of an issue with my method or I've bought myself a new toy to do all that for me.Ā
Hi TĀ  the bestway to store a balance is to lie it on its back with the balance upside down on the cock and cover with a glass. There are all manner of balance holders , some good some bad. If you are adjusting the collet , the tool shown and suitably modified aka Hector's post so the balance is held on the device and the post adjusted to support the balance and get the spring to lie in its horizontal plane at rest. I dont think the balance springs of today are as soft as those in the past. The damage is done when the balance is left hanging with no support for an extended period.Ā  The safest and cheapest way is to put it on its back.Ā Ā
32 minutes ago, Tiny said:
Thank you WW and NEW
I did write a long long reply but deleted it so I didn't look BLUNT just to keep the friends I've made on this wonderful forumĀ
Sometimes blunt gets the job done my friend. I like people to know where they stand with me and me with them. I'm honest and genuine. I don't BS and say things as I see them. When I think I've make a mistake I will hold my hands up and apologise. Life's too short to have it surroundedĀ  by drama , been there done that didn't like. šŸ‘
Tiny mate here you go a simple visual. Photo 1 this was me when I started.
Photo 2 this is me now.
High tech or what.Ā
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811ukĀ close but no cigar šŸ™‚ I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123Ā I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively šŸ™‚ ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ Ā
    • As an alternative, clear nail Polish, the advantage is you can have a manicure at the same time.Ā
    • I use Grammarly. It works really well and If English is not your first language, you will also receive help with formulations. There is a free version that covers most of my needs. It installs as a plug-in and works with all browsers and word processors.
