Valjoux 7733
Finally got this chronograph up and running it needed a new fly back lever ,got one from a company called watches ulike in France It has a sterile dial so no idea of maker,I guess it's 70,any thoughts?
Hi ro63,I see that Brietling,Huer and many others used this movement, the only one I've seen that was anything like it was a Avia Marineo,there does not appear to have been anything on the dial,so I don't know if they were sold new like this ,and if so why,I imagine it was a fairly expensive in its day,so you would think the maker would want their name on it.
Is there a calibre number underneath the balance wheel? The Dugena I have shows "7733" underneath the balance and, if I recall, the Russian clone has "3133" engraved on one of the bridges. As for the watch being unsigned, well, I suppose any maker could grab a movement and add hands, dial and case. Why - I've even done it myself!
Other than that, I don't know much more.
That's certainly a possibility. My guess is that a small watchmaker has bought some 7733 movements, cased them up and sold them. There are any number of unsigned makers/sellers out there that have done that over the years.
Whatever - enjoy the movement!
I think that watches were supplied sterile so retailers could put the own name/logo on if required. some small retailers probably didn't want the additional cost so left them as was. I have a 7734 with the name Jean Decret on the dial but have been unable to find anything on the brand at all!
Dugena used the 7733 in their chronos - though they changed the calibre number to 4002. A bit like Poljot copying it and calling a 3133.
If i remember correctly . the 3133 wasn't a direct copy, they added more jewels to the movement as well.. and the parts aren't interchangeable (well the parts i wanted unfortunately!)
7733 & 7734 have been nice movements to work with. think the difference is the 7734 has the date..
Thanks for your info guys,I reckon your right Maurice,makes a lot of sense,love your watch,and what amazing condition,and as you say jnash the 3133 has 23 jewels, I have two 3133,s a Russian airforce one and a Russian navy one .
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
