feeling silly
I do hope I'm not the only one but I found the blue second hand for my Fossil watch so I thought I would clean the case ready to build tomorrow.
new sonic cleaner arrived today as well so cleaning I noticed some finger prints on the new glass front also a bit off dirt on the case back so I cleaned the case and was going to put both case and case back in together but stopped as I didn't want them rubbing together add scratches so decide to do one at a time however now it comes to clean the case back I can't bloody find it
ONLY BEEN IN THREE ROOMS office, living room and kitchen and can I for the life of me find it
It will turn up but when I will never know lol
Ha ha found it.
Under the coffee machine in the kitchen on top of sonic instructions that had gone underneath my coffee machine. But now I'm in two minds to polish it.  I will see tomorrow if I can find my wizard( black and decker) Dremel
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
