Broken stem clutch lever
I am working on a pocket watch that has no identification on the face or internals.  No manufacturer or serial numbers.  It has a broken stem clutch lever.  See photo.
I searched to try to find something but came up empty.
Has anyone tried to actually make a piece like this?  or have any ideas on how to handle this kind of situation?
Thanks
bob-o-link
Thanks
bob-o-link
Buy a set of feeler gauges from Amazon and the pick one that has the same thickness and start cutting with a dremel   tool and drill out the hole first. Then get out the files.
It's handy to fix the broken part onto your steel stock and use it as the guide when grinding/filing/sawing it out. You can use super glue, but sometimes the part de-glues right at the wrong time. You can soft solder it and it will be more secure; an excellent solder for this is Tix, along with Tix flux. It has a low melting point but is very strong. Feeler gage is a great source of material, though you might find it's too hard to drill without carbide drills, and will resist a jeweler's saw blade, but will grind and file fine.
17 hours ago, bobolink said:
Will get Tix and try it.
Is this the same watch with the broken Balance Adjustment Pointer?
While the feeler gauge idea is great, it seems that by now I'd have given up on this "practice" movement and either found one to cannibalize or started working on another.
Let us know how it works out!
No this is not the same watch as the broken pointer.  I am starting to think the same.  Move on.  But I do want to try to make the clutch lever.  If that doesnt work out it will be time to move on with this watch.  My other watch is the one with the broken pointer which now has a broken hairspring.  Sighhhhh.
I may be learning something here. If you're going to do old pocket watches, it may be favorable to focus on the popular names like Hamilton, Elgin, etc. where many basic info and parts are available.  All especially when you just learning.
Ok...here we are.  Thank you JDRichard for your advice on the feeler gauges. Also to everyone for your comments to this novice.   I had a set of feeler gauges (I dont use anymore. After all who gaps sparkplugs these days 🙂 ) and tired making it and it worked!!!!.  See the picture (#1 is the broken piece, and # 2 is the piece I made fitted into the watch) of the broken clutch lever and the one I made installed.  It was definitely quite a bit of work.  But time wasn't the problem :-).  I didn't have time to get the Tix so I tried a few things and really wanted to see what it takes to make such a small piece.
First tried super glue and JD was right, it popped off pretty quickly.  But I then roughened all the surfaces and did good alcohol cleaning, then epoxied the feeler gauge to a piece of 3/4" wood, then epoxied the broken piece to the feeler gauge.  I then cut it with the rotary blade on the Dremel.  I was very careful, slow and steady.  The wood seemed to stabilize it.  Then a lot of filing and emery paper.
PS:  I was surprised at how hard that feeler gauge steel is, it can really take a beating.
Thanks again.
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
