Hi, I'm Robin from Scotland in the UK
I've ended up here having watched a you tube video - or 40 just looking at the possibility of watch repair being a hobby, though having just braved the strange world of replacing a battery I'll admit I'm a little out of depth!
I'm a bit of a Casio fan but looking to change that and move to a mechanical at some point soon.
Hi Robin,
Welcome to the forum!
Where abouts in in Scotland are you? I'm Fife based myself.
Changing a watch battery was what got me into the hobby, I've just kept pushing myself further each time, wondering "if I can do that then I can surely do this" and am definitely hooked now. Certainly requires patience though, I've just spent the last hour on my hands and knees trying to find the worlds smallest spring in my carpet...
Mechanical watches still amaze me to this day, how can something that can be made by hand be so reliable, accurate and efficient. Only trouble is, I have too many grail watches and not enough money for any of them, yet!
James
Thanks for the intro Robin, welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement.
I started replacing batteries years ago out of a sense of frugality. Usually doing it yourself is less expensive however I tried to replace a battery in my wife's Movado and crushed the crystal trying to get the back back on. At the time replacing the watch was the fastest way of keeping my mistake a secret  😞
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
