Hi everyone,
Sorry for being quiet, just busy with work, kids and watches (which I will spend an evening photographing the collection / fixings).
Does anyone know of anyone that stocks latch springs in the UK? I know of daveswatchparts in the US but was hoping there was someone that sold old pocket watch parts in the uk? Or can you buy new or NOS universal ones still?
Its for a beautiful 1873 Fusee that needs a fair bit of TLC.
Many thanks, Charlie
Let others feel free to answer also, because I can make no promises, but I possess a bunch of old latch springs.  I could send you a private message, wherein I would request the most accurate measurements you could make (thickness, length, width of latch section, etc) and a tracing on paper of the spring which you could scan and attach or mail to me, and high resolution photographs.
Don't stop looking though.  There are a great many different kinds of latch springs.
This will be like looking for a needle in a haystack no two are the same. I have seen them on ebay in collections of old watch parts. One of the reasons you find they are without the case is the cases get sold for scrap and all parts that are not silver or gold have to be removed because they add weight no matter how little. You might find one you can adapt but getting it to fit correctly and the screw hole to line up will be hard I don't know of a tap that small that you can buy and I haven't a clue what thread it would be, something odd that's for sure.
  • Thanks 2
4 hours ago, oldhippy said:
... One of the reasons you find they are without the case is the cases get sold for scrap and all parts that are not silver or gold have to be removed because they add weight no matter how little.
Scrappers break my heart sometimes.  A few of them have ethics, and they try to ensure that the watch they scrap is a non-runner that is mostly beyond hope.  But some I swear will scrap a watch that may only need a good cleaning.
Either way, OH says it better than I can.  Even if we locate a latch spring that could possibly fit and may do the job, it will almost certainly have to be modified in some way.  I've only gotten lucky a couple times, and I still had to file down a couple surfaces and drill a new pin hole before the spring was set to do the job.  It would have only been *slightly* more difficult to make a new spring.  That's the sort of task you'd be facing.
Thanks so much for the advice, so very little chance then. Think the easiest would to make one from scratch then as all the parts are there. Whoever broke it kindly popped the broken off piece in the back of the case. Can go in the long line of projects!
Managed to buy 60 movements off of ebay for £1 each for spares but recon 50 odd are good projects to learn repairs on and are salvageable. Started my first movement from this lot this week and had to learn how to rivet my first fusee chain (I added the hook) and slightly straighten a pivot. I'm amazed at how little information on the web there is on repairing fusee chains. Pleased to add that it all worked out and is ticking along nicely 🙂
612230600_s-l1600(4).thumb.jpg.bcb0f2b7d05521186ea0a5e3f9488846.jpg1481740775_firstrivet2.jpg.1f2b6f06665aaf54f2c33e014e3ec304.jpg1432911454_Photo05-04-2022182556(1).thumb.jpg.9da24769324d5aa0bcb2a869c556a592.jpg
Fusee pocket watches are one of the hardiest movements to repair when it is a verge escapement the balance staff type can also be a headache.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
