Custom Desktop Bench
Don
I got a bug in my **BLEEP** to improve my work space situation. I don't have room for my own dedicated bench so I'm always having to take out and put away tools and deal with a desk that is too short and covered with the kids' school books, mail and junk. I looked into the small desktop benches at around $100 but read that the quality is iffy. So I decided to design and build my own.
Here are some sketches I made.
Instead of all drawers, my design has a row of three drawers on the bottom and two cabinets on the top row. The cabinets will hold some of my larger tools.
The bench will measure 22" wide by 11" high by 16" deep. I decided on 1/2" birch plywood for the main material. I bought a half sheet Friday night and cut the top, bottom and sides today. That's probably it until next weekend.
By the look of your sketches I suspect you could be in for some serious back ache. There's nowhere for your legs to tuck under so as to get your upper body close to the work area.
Only pointing out as I suffer from severe lumber pains due to hardened L5-S1 disc and it ain't a nice type of pain.
Ah. Tapatalk failed to load all his post. Now I see it on a browser it shows the last pic and dimensions.
I like the idea of an add on part. I'm in the same situation. No space to call my own so would solve my problem too. Might actually finish one of my projects.
I probably couldn't make it for the cost either. But there's nothing like spending lots of time making something it would be cheaper to buy.
Plus I got to get some new power tools. [emoji12]
Looks good Don, will you be lifting it off and on the main desk? I'm just thinking of the worth of adding side handles and latches on the doors/drawers to stop them opening when you don't want them too.
What new power tools did you have to get :-) table saw? router? disc sander? biscuit jointer?
How are you jointing the carcass?
:cool:
Happy sawdusting
Sean
Thanks, Sean. Yes, I'm planning on adding handles as it will have to be moved. I'm also planning on something to keep the drawers and doors shut, but I haven't given much thought as to how yet.
No room for a table saw. I lucked out and got a barely used Ryobi router used for $25 and a 10" Hitachi miter saw for $60. I bought a new corded drill, just because I wanted one. I bought a new circular saw and immediately changed the stock blade to a 60 tooth Freud. The last time I saw my old circular saw my brother had used it to cut its own power cord in half.
I got a pocket hole jig a couple of weeks ago and I'm planning on using that for the majority of the joinery. For the interior dividers that form the drawers and cabinets I'll probably pocket screw them into one piece and cut grooves in the carcase with the router for them. I'm still in the "I have no idea what I'm doing" stage.
The 1/2" ply I bought is terrible. The veneer is about the thickness of an atom. I may have to think about my material choices...
Welcome to the forum!
Don
Hi Don,
I think in my profile says I'm a carpenter and cabinetmaker so I can speak with some experience.
You are embarking on a big project with a limited skill and tooling.
That said, you should look into Finnish/Baltic birch plywood for your carcass and for your drawer/door fronts and 1/4" tempered Masonite for your drawer sides and bottoms.
It will take a lot of pre-layout to rabbit the corner, back, and top joints. Then you have to dado the joints separating the separation between the sections all before you put the box together.
As far as the drawers go together, you can do a simple rabbit joint and dado for the drawer, Masonite being used here.
To hardware. You can use a SOSS hinge which I use a lot and are great, http://www.soss.com/invisible-hinge/soss-invisible-hinge.html?invisible_hinge_mat_thickness=30
or a simple miniature butt hinge like you see on your front door.
To keep the doors and drawers closed you could use a bullet or ball latch.
A router is fine, using a guide to cut the dados and rabbits but a hand held circular saw will be tough to get a straight cut for all your parts. Better to buy one of those small table top table saws you can find cheap on Craigslist. You can do all your rabbit cuts with it as well.
This is a great project and I wish you luck. I just found that to buy the cheap unit from the supply houses suits my needs and didn't have to put in lots of hours and money away from my business.
If I was to need a full sized watchmakers bench, then I would be looking to design and make it myself.
If you need any help or advice, please feel free to PM me here or PM me with you phone and I'd be glad to talk.
Stu
edit to add, your pocket screw jig is good for kitchen cabinets but almost useless on something this small. Think large jewelery cabinet. :)
Edited by Gotwatch
Thank you very much, Stu. I'm thinking I should do some easier projects first, but we'll see if impatience chooses for me.
I have looked at getting some decent (not big box store) birch plywood. Do you suggest 3/4"?
Don
No, Don. 1/2" Finnish (like the country, Finland) birch should be fine. Finnish and/or Baltic birch ply has many many plys with no voids. It's a great base material. You can find it in smaller sheets at many supply houses. Try Pinecone Lumber over by you for a start. You won't find it at a big box like Hope Depot.
Thanks, Sean. Yes,I'm still in the "I have no idea what I'm doing" stage.
:-) who isn't Don ;-)
Like Stu said, the pocket hole jig on its own will not be enough to hold your desk together, at the very least combine it with dowels, which you glue in. Once full of tools this is going to be heavy, you don't want to be stood in a puddle of splinters and tools with two side panels and handles in your hands!
When you come to route your dados a jig like this is fantastic dadojig if its new to you shout and I'll dig my similar one out and mock up some pics on the theory of it working.
You can do loads without a tablesaw, using a circular saw instead, but try and make it easier on yourself, when you get your ply, get as much of the cutting done on the big wall saw in the place you buy it, it should be cut to dimension and with nice straight square edges.
Also build yourself a couple of jigs, first a cutting deck, to put sheet material on when sawing and routing, mine is a lattice of strips of ply wood that slot together (I realise that doesn't mean much without a picture sorry) and a straight edge guide to run the saw along, that way you can have a setup similar to the track system (festool hmmmmmmmm) used by many of the newer plunge saws.
If you want ideas for jigs have a look at the dvd's available from Steve Maskery, he's a woodworking legend! and one of the UK woodwork magazines refers to him as The Jig, he covers all the ones I've mentioned and many many more besides.
Handles - the type that spring to mind are cargo luggage handles, they fold flat but only open to 90 degrees when lifting, saves the hands getting crushed.
Good luck and enjoy :-)
Sean
Wow - I WANT ONE!!!!
Ive been looking to try and buy something very similar - so I can tinker with watches at chin height on a normal office desk) - but they seem to be only available in USA and Canada (no international shipping).
Was going to stick a whiteboard on top of a couple of storage boxes with velcro (I saw a web page with someone doing that), but what you're building is a million times better.
Good luck, and ill be following your progress :)
Dean
Thanks, Dean. I will update when I make some progress. So far I'm trying out some different stuff and borrowing a table saw. I'm trying to make it easier and cheaper for me to build. If my new design works, I'll post some info on how I built it. May be a while, though.
In the meantime, check out Geo's solution. I'd go this way if it weren't that I wanted storage.
http://www.watchrepairtalk.com/topic/841-workbench-height-solution/?hl=workbench
Don
The height is about 25cm. I (very unfortunately) have a problem with my corneas - so I need to get right up close and personal with what I'm working on. That movement holder is just below eye level when I sit up close - sooo comfortable [emoji3]
Thanks Don - just spent most of the day on it taking apart a couple of Waltham movements - perfect working height - but didn't stop me pinging several critical pieces onto the floor never to be found. Just ordered a strong magnet and a proper pair of decent tweezers lol [emoji3]
  • 4 months later...
Progress has been slow on this as I don't have much time and I've had to slowly acquire tools and materials. But I can see the light at the end of the tunnel. The design has changed a lot from what originally sketched. I had to make it simpler for me to make.
Friday evening I cut all my drawer parts.
Today I assembled them. The one on the left looks wonky but that's just the perspective.
Here's the current incarnation of the bench, with drawers.
I've still got a fair amount of work. First I need to scrape and sand off a lot of excess glue. :startle:
Then I have to make the drawer fronts and the rails for the top. I'm thinking of making them out of a contrasting wood. I had some mahogany, but it looks like some bugs got into it. After that I've only got to sand, finish and install drawer pulls.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
