Vintage Timex cleaning and amplitude
I got ahold of a vintage 1967 Timex Marlin, one of the ones with a jeweled movement, and I have a couple question about it.  I understand we have a resident Timex expert in @JerseyMo, but anyone with insights can chime in.
Firstly, is the "dunk and swish" method of clean regarded as an acceptable way to clean these watches?  The one I have does have screws, but being full-plate, and with what appear to be various spring held in place only by their own tension, I'm concerned about reassembly.  Are there any guides or tutorial out there that cover a full disassembly?
Second, what kind of amplitude should I expect out of a reasonably serviced movement?
Lastly, any information or tips on cleaning/oiling these jewels that appear to be capped?  It looks like there's a retaining spring, but I'm not sure how to remove it or what to expect if I do:
Edited by kibbler
wrong year, and clarifying question about the jewel
FYI if that is the movement inside your watch than it is not a marlin.....rather it is a 21 Jewels automatic.
You can try the 'dunk and swish' as you so call it since it requires little effort.  But know that those cap jewels need to be oiled too.
Thanks,  I'm still learning.  I was able to remove the cap jewels with a properly sized screwdriver, based on the instructions in the service manual.
I gave it a preliminary oiling after an initial immersion in naptha, and it's running at ~180* amplitude.  Is that terrible?  It seems low, but I know the Timex movements don't follow all the same principles of Swiss movements.
Do you tear these movements down further than the service manuals recommend, or stop with removing the balance wheel?
*edit* I see that the 1961 service manual includes instructions for removing the pallet fork and escape wheel, while the Model 72 service manual does not.  Is that only for replacing/repairing those parts, or for cleaning as well?
Edited by kibbler
As a beginner, I would advise you not to do a full disassembly. It is very difficult to get the plates together again.
Probably when you become more experienced, then a full teardown and clean would be better, as naptha is not the best cleaning agent for dried up lubricants.
I've only done one of these 21 jewel movements several years ago and it's NOT fun. You have to modify a screwdriver tip to fit the slot in the cap jewel cover to remove them. And they have a tendency to escape and disappear. Getting a replacement jewel would be next to impossible.
At the end of the day, it still looks terrible on a timegrapher, but keeps good time and looks good on the wrist.
Sooo.... Good luck and keep us posted
Well, I took the balance out today, along with removing all the cap jewels to get everything clean and oiled a little better.
I have to say upon trying to reinstall and re-pin the balance, I thought I had made a huge mistake; that thing is fiddly as hell and it took me ages to get the pallet and the spring in the right position again.  I finally got the pin back in there, only to see on my timing software that I had ~12ms of beat error, and it was running +180 s/d with the regulator maxed out.  I had inserted the spring too far into the pin slot thing.
The second time around, things went a bit more smoothly. The last coil of the hairspring still isn't perfect, but at least the amplitude went up, the beat error went down, and I managed to get reasonable  (for me) accuracy
Edited by kibbler
wording
agreed with above replies.  I go with the path of lease resistance …
three stage cleaning method. ammonia, water rinse, lighter fluid,....air dry in between.  aid by ultra sonic.
full tear down only when I need to get out some frustration and get to curse and throw tools 🙂
timing machine!  I do not have one and don't want one.  I get them running, wear them and adjust best I can.  Even I know these are only Timex and not the other famous "X"
Yes, I was using it more as a diagnostic tool (is it running ok?) rather than to get precise timing.
Do you know what size gaskets these watches use for the caseback?  I ordered some 30.0mm x 0.6mm based on the one that came out of it, but seems a bit loose and/or thin
never measured one actually.  I have a huge stash of parts I go to when needed.
I got everything back together, polished the crystal a bit, and added a band.  The winding rotor has a bit more side-to-side play than I would prefer, but it seems to work well, and makes a very satisfying sound.  I have to agree with you that it looks good on the wrist.  Here are a few photos that I took during disassembly and after cleaning/reassembling
PXL_20220314_200449677.thumb.jpg.fef8ac219e1b1bf3983b019382074275.jpgPXL_20220314_200659021.thumb.jpg.c0fc8ca70675a65663590ff11e5e7943.jpgPXL_20220314_201057356.thumb.jpg.9ddbb3ca6e162b28afbdfbda67a46834.jpg
Reassembled:
PXL_20220315_234225998.thumb.jpg.2f486be66eaa552c08656152e8265d6b.jpgPXL_20220316_005859892.thumb.jpg.7f54af767a9a066a06eee9f40c85bc82.jpgPXL_20220316_005823388.thumb.jpg.344634e18c85a241b3bd376781652fdd.jpgPXL_20220316_022127612.thumb.jpg.17bf116a85efe16602a16eb537816543.jpg
Edited by kibbler
    • The entry and exit stones have different impulse face angles  murks.
    • Depending on how much of the screw is left, you may be able to screw it further in and it may fall out of the hole that the dial foot sat in. To do this I rough up the tip of the good screw and screw it in, often the rough surface of the good screw and the rough surface on the broken screw get enough of a bite to transmit the torque into the broken section and force it out the other side. Like I said the size of the broken screw needs to be in your favor, but you never know you may get lucky.... or if you get it moving you may be able to then back it out with a screwdriver taking a bite on the rough surface. worth a try
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
