Hello, I have an old Tissot 660t that has stopped working. It's on it's 2nd movement (which only lasted 3 years), but I'm told that there is not a gasket available for the water resistant gasket. It could be fixed but would not be water resistant. I don't think it would be worth fixing without the gasket.
I'd like to get a second opinion from some experts.  Thank you.
It all depends on your intended use of the watch, If going swimming or diving etc, then getting a gasket fitted is essential as is pressure testing. But if its for general wearing  or occasional use then not so. I myself wear a watch daily that is standard and would not pass a waterproof test but for many years has had no ingress of water during normal use. There may be generic gasket that would fit. My supposition is that there are no genuine gaskets available, Generics quite possibly.
Have you opened it up and measured the original or the casee ?
I find out a interesting statement as it looks like a screw off case back it's probably just a round gasket.: If you're worrying about the gaskets what about the crystal and the crown both of them have gaskets.
Then it be really nice to get a picture of the inside of the watch showing with the gasket goes, a picture of the gasket and the inside case back. I might Be able to look up the actual gasket specifications but I need an exact case number.
Thanks, good info, Wouldn't humidity eventually get in there and short out the mechanism?
I haven't opened it up. All I have is some standard pliers. It's not so easy opening that thing without the proper tools. I want to be able to get it back on, too, to keep it in a sellable condition.
I don't care if the gasket is genuine or not, a generic would be fine.
Not sure I can get it off with the tools I have. I'm just a layman.
Hi as far as condensation occuring , that usually happens when moisture is already in the watch and the heat from wearing the watch condenses it. If its kept dry and not imersed in water for periods ie swimming etc should be no problem.   There are inexpensive tools on the internet for removing the case backs for under a tenner,  ok for occasional use  not professional tools.
Unfortunately this is a watch repair discussion group we thought you were in watch repair Or this was your start in the watch repair in which case some basic tools will be needed.
Without the basic tools to take the back off and put it back on again your options become very limited. To basically finding somebody else different in watch repair and taking your watch they are letting them fix it.
I apologize. I was not aware. Thanks for the helpful comments I got.
Apology is not necessary.
There's no problem with asking watch repair questions. The problem becomes whether you want to fix it yourself or find somebody else to fix it for you.
As a matter of interest, when I took it to an honest watch technician, all it needed was a cleaning. The gasket was fine, and the movement did not need to be replaced. I was lied to by the first shop I took it to.
Out of curiosity how did the honest technician determined that the gaskets were good? The reason I ask is the only way you can really tell is they have to have a waterproof testing machine. You really can't look visually at the gaskets on the other hand the person who said you couldn't replace them was also incorrect because I'm sure they could be replaced even with generic round gaskets because people do that all the time and then it would pass a water resistance test.
Then I assume the watch is now running as you had the second shop do the servicing?
Then it isn't necessarily honesty that is causing the problem. There's a lot of shops that won't even think of servicing a quartz watch that means the only thing they can do is replace the movement. In other words basically you have unskilled individuals who can't repair a watch.
  • 2 years later...
It's been a while since your post, but I'd like to add some information.  I've been into watches for years, and it's always awesome to chat about them with someone who shares the passion. There's just something about the craftsmanship and style that makes them so special.
One thing I find fascinating is watch resistance. It's amazing how some watches are built to withstand just about anything! Whether it's water resistance, shock resistance, or even anti-magnetic properties, it's like these little machines are ready for any adventure we throw at them.
For instance, I have this one diver's watch that can go 200 meters deep! Not that I dive that deep (or at all, to be honest), but it's cool to know I can handle it if I ever decide to take the plunge. And then there's the G-Shock series, those things are like tanks. Perfect for when you're out and about, maybe hiking or doing something where you don't want to worry about your watch getting knocked around.
Edited by Fenderyzz
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hairdrier) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
