New to watch repair
Hello If you have bought the watch for practise work, ok but I should maybe start on something a bit larger (pocket watch)  the components are a bit larger and easier to handle, and when you have done it over two or three times without mishap then have a go at the Audax. Its a nice little movement
If its working of sorts now then probably a service will suffice but be aware of other problems like gunky jewels and chipped/cracked jewels. You will need some good magnification , some oils/grease and a great deal of patience  any problems just post them and the members will assist you. We want you to suceed in your endeavours.            cheers
To answer your question.  Yes it does need a service.  That entails a complete teardown  and inspection of all components.  Looking at the pics it appears as though there is some "foreign material" stuck up under the barrel bridge and the third wheel...  As a fellow newbie (bout 9mos now);  I completely agree with the other folks!!!  Do several pocketwatches first.  Also some suggested reading that helped me is Practical Watch Repairing by Donald de Carle and Watchmaking by George Daniels...   How are.your tools???  I found that quality tweezers made a HUGE difference.....  Best of luck, were all here to help.
 If the oscilator is good, runing it sustainablely by adding power to any gear of the train should be possible. in which case a good clean and lube should suffice. Your adding  power to the train to check if escapement can be made to do cosecutive escapes.
 Nevertheless swing of the socilator is no gurantee a movement would run with just a clean and lube.
I make a habbit of,
1-  Checing the end shake on balance staff and at least  fork arbour , escape wheel
2- Check if balance pivot can easily be forced to leaves the jewel hole.
3- if balance wheel or any gear wobbles.
4- Once disassembly gets to the gear train, see if the train runs freely, ideally it should do a back spin at the end.
Actually this type of setting should be taken apart to check the jewel hole and face of the end stone.
3- Every part can be tested as you disassemble ( see if its doing what its suppose to do )  so the movement is often diagnosed and fixed  before the clean. A preclean is real helpful.
Check if the oscilator runs freely without the fork in place.
and If the fork jumps to the banks with a gentle tweak and pallets are aligned and aligned/ level  with escape wheel.
So, what we doing is checking each part.
Good magnification make life a lot easier.
Regards
Nothing wrong with removing dial screws, if ithey don't want to come out, putting a bit of oil on them helps.
24 minutes ago, RichardHarris123 said:
Removed the hands and dial, it is now running, any idea why?
So something must have been hindering the gears there, old dried oil or dial plate pushing on gears, you just ought to keep testing everything to find out. Could even have been the stem setting the keyless bad.
So you have a movement to clean and find what under the dial was hindering it from running.
For tube ID of the seconds hand  , measure OD of the sweep pinion
Good luck
Good luck
correction sweep arbour , not sweep pinon.
12 minutes ago, RichardHarris123 said:
I'm having trouble getting the stem to lock in place.
Turn the stem a bit as you insert it in. How bad and in what section is it bent?  repairing it with a  Stem extender might possible ,its cheaper and readily available.
Check the keyless and if stem square section doesn't want to enter the sliding pinion.
Are you set up to show us vids?
6 hours ago, RichardHarris123 said:
Thanks
Good screwdrivers, cheap tweezers, I will invest.  Stem screw missing, any ideas about replacing it and movement on can cases be bought?
Investing in good tweezers made a TREMENDOUS difference for me.  I could then pick up and manipulate/place screws, parts, etc.. with confidence.  Instead of sending them into the "fourth dimension"!!   I've got a smattering of Dumont, Vigor, and even a couple of good Indian sets...
13 minutes ago, Nucejoe said:
How about getting dumont for hairspring work and small springs ( that be No4) and low quality ones for other tasks.
GREAT ADVICE!!!!   I literally JUST checked Ebay and there are some pretty good deals on used Vigor and Dumonts. I have 2 pair of Indian and one pair of Pakistani tweezers.  They are good tweezers but I prefer the feel of the Vigor or Dumont.
That being said; I was a professional auto tech for many years.  So I have grown accustomed to a certain "feel" for tools.  Dumont, Vigor, and even Bergeon don't hold a candle to Snap-On in regards to pricing!!!!
I'm not saying to put a large outlay in tools and other equipment.  Start small and see where the hobby takes you!
Agree,  that snap-on is expensive and the jewel of the crown in auto repair tools.
The feel of a tool is telling us, you got more control over the task to do a finer job.
 Screw drivers are a different story though, often you need to dress one for a near perfect fit on a small  screw, but when you get to other screw/ movement it needs dressing again for a good fit on the other screw.
A master repairman is to remove/ replace these tiny screws without any damage or sign of it ever having been repaired. Imagine handing an audemars piguet to the owner with screw slots showing sign of having been worked on or damaged.
Regards
    • VWatchie I have followed Adam since his start just over a year ago.  His videos are full of information and usually diplay a full disassembly and build. What is interesting for us beiginners is that he shows screw removal and placement. Plus he talks about what he is looking for when completing the install of items. Also, he includes the errors so that we can see where not to make the same mistake.  His oiling and cleaning process has altered. Less is more, but enough to be enough.  Adam of 'Weekend watch repair' is a member of this forum and has given information freely to many. As do you members.  I am doing another build of a Seoko Mellmatic 4006, so am using https://www.youtube.com/watch?v=H2UOIUcUEYA&t=3290s His latest shows the difference in his oil and cleaniing application.  Like him, I also have adapted. Don't have his equipment, but feature his system.  ish... https://www.youtube.com/watch?v=_UCNqdRq6mI
    • Fantastic, thanks!    oh... and if it's not too much trouble, how long are they? I'm trying to gauge if it would work to stick them on a stake in my staking set and still have enough space to actually put in the movement (and hands)..
    • They seem to have gone to great lengths for a cheap watch. Check the crown for the broken bit being stuck inside or damaged threads after being pulled off. The un evenness of the stem end might just be the previous repairer did not tidy up the end after cutting it to size, found a few like that.
    • I think we can be fairly certain that the propper cleaning fluids and rinses would remove the rodico residue based on some of the experiments recently carried out
    • @Malocchio @GuyMontag I received the recommended adapter and could make it work. Thanks the camera view is now going to a monitor and I am getting a memory card to be able to take pictures and videos.
