Identifying lathe collet sizes.
Since I buy most of my tools second hand, especially those relating to lathes, I've ended up with quite a few unnumbered collets:
I only have pin gauges going up to 1mm in diameter and since they can't be measured with a caliper either I decided to use my lathe to measure them properly. I started with a 40mm brass rod and I'm gradually reducing it in diameter in 1mm increments until I identify each of the unnumbered collets; plus, I'm checking the condition of each of my numbered collets at the same time. Not sure if there's an easier way to do this but if nothing else it gives me a bit of practice time on the lathe 😀
18 minutes ago, jdm said:
These are good https://shop.vogel-germany.de/test-equipment/jet-gauge-1-50-3-00-mm-16-blades.html
Also available 0.45 - 1.50mm. Apparently discontinued, that is the best price I could find.
Cheers, I was expecting them to be far more expensive, I'm just assuming watchmaking tool prices!
Any ideas how to permanently engrave the sizes on the collets? I've got a Dremel engraver but if there's a better tool/method...
Maybe photoetching? I've never tried myself, happy enough with a label printer and clear tape.
18 minutes ago, nickelsilver said:
Keep in mind that the fact that a pin fits doesn't mean that's the size of the collet. They are usually sprung slightly open as made, and you can fit say a 2.1 pin in a 2.00mm collet- but it won't close correctly, run true or securely.
OK, maybe I'll just label them with permanent marker for now. I've been measuring them by making sure they go on freely and then hold with just pressure from gripping the end with my hand. So, my '25' could be actually a 24.
My method is flawed but I do have a general idea of the size, I'll just have to remember my numbering could be off when it comes to using them proper. Cheers.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
