Evenin' all!
A little earlier, by way of relaxation, I opened up my box of assorted watch parts. I bought a small job lot of bits from the Bay place about a month ago but haven't really properly scrutinised everything that came. Thus it was, as I studied the various movements with a loupe that I found a largely complete movement with the mark 'REBBERG DEPOSE'.
Naturally, I Googled this and found not a lot but there was a reference to Rebberg and Rolex in one particular article. Heart skips beat!
In a item in the Rolex Magazine Blogspot I found this illustration:
If you compare that illustration with a pic I just took of my movement you'll see the similarities, albeit that mine is differently handed - not quite a mirror image. Clearly mine is missing the barrel wheel and screw that might have had the Rolex name on it. Bah! Also a couple of bridge screws.
The dial side is lacking the 'wheel in the middle' whatever it's properly called but the keyless work seems complete.
Does anyone have any further info about Rebbergs and an insight into how likely it is that this might be an early Rolex. I'm grasping at straws here I know but what fun if it were!
Cheers
John
Thanks Will, that's interesting. I think mine would benefit from a good clean and a little scratch removal on the train side. Maybe this can be my first cleaning effort using the Brenray. I have my uncle's gold Bulova case and bracelet to do before I get it down to the jeweller for appraisal so they could go for a bath together.
The Bulova has an inexpensive quartz movement but, with a very nice 14k bracelet, should be worth a bob or two. I don't think that it will have any greater value simply as a watch.
Another item in my job lot turned out to be a Slava 2428 movement, or most of one anyway. Found a few online that look quite attractive but they don't seem to be very expensive. Like my favourite Favres the 2428 has a twin-barrel arrangement, so interesting from the technical standpoint.
Oh I'm lovin' this hobby. There's so much out there to learn about.
The Rolex pic above came from an item here:
rolexblog.blogspot.nl/2010/07/we-want-to-be-first-in-field-and-rolex.html
Nice find. Always good to unearth an interesting movement/watch in a job lot.
Shame the previous tinkerer saw fit to use a pen knife on the screws [emoji35]
Roberto, yes, **BLEEP** criminal! That may explain why he nicked the barrel wheel, which might have given a clue to the watch brand.
I may be able to remove the signs of surgery but restoring the pearling/engine turning will be a bit tricky. Any tips anyone?
What IS the name of the 'wheel-in-the-middle' on the dial side? It might help to know when it comes to searching a replacement out.
Looks like your missing the cannon pinion along with the hour wheel.
Very interesting find. Good luck with the parts sourcing. Make sure you post pics if you bring her back to life.
Daniel
Hi Clockwatch, I really like wrist watches from this era. I have a couple of Rebberg's which I thought you might like to see, which are not one's that were sold to Rolex. The cases are marked Rebberg, and one was branded by Lancet. You will see the movement was also marked Rebberg. I am pretty sure your find is a Rebberg that was sold to Rolex and the ratchet wheel would have been marked with Rolex branding. It is a nice find, even if only for spares
  • 8 years later...
On 5/7/2015 at 3:27 PM, clockwatcher said:
That makes sense. Cheers Roberto!
Did you figure it out? This is mine and it I’d the movement Rolex used.  Mine is a doctors watch.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
