So I was following a tried and tested procedure for replacing the gasket in the crown of this Seiko diver. For those who don't know, it involves stuffing small gaskets into the available space, squishing them down, which results in the washer popping off so you can get the old gasket out. (See here for more info: https://adventuresinamateurwatchfettling.com/2015/10/12/crown-revival-seiko-6105-and-62mas-crown-gasket-replacement/)
I used a pendant tube to do the squishing. It worked: the washer came off, got the old gasket out, But now the pendant tube which I used to do the squishing is stuck! In the photo I've put another of the same tubes next to the crown so you can see which is the part which I need to unstick.
I have tried:
pulling it out with a pin vice
heating it
dissolving it in alum
pulling it out with a magnet
pulling it out with a pin vice +superglue
soaking in acetone to dissolve any remaining rubber which might be sticking it
vibrating it in the ultrasonic washer
soaking +vibrating in WD40DSC_1011.thumb.jpg.1ce59b9c4c2acfc5241593976ef259ed.jpg
Do you have a good hold with the pin vice? I doubt you do, because the nose of the collet is almost flat.
Anyway, if you can't grab it, you can cut it, ideally on a lathe. Since you probably don't have one, I would then take two sharp screwdrivers, 2 or 2.5 mm. See if you can cut some grooving on two sides. Then prying there up with two drivers.
You could try gluing a longer, tight fitting tube over the pendant tube and wriggle it out. Hope it doesn't end up like the nursery rhyme "Why did the old lady swallow a fly?"
I'm actually right now in the process of doing just this, just waiting for the glue to set properly. And the thought did occur to me that I might be making things worse!
This might work, though I'd be concerned about damaging the sides of the crown while prying with the screwdrivers...
Then place a roundel of copper or other suitable material on top of the crown. Once you get a good grip, not much force should be needed, but if the tube has been really press fitted then it will have to be cut.
Phew! Done it.
Superglued a stump from the jewelling set onto the tube.
Then couldn't get the stump out, no matter how hard I gripped with the vice. Eventually jammed it in a door, gripped the crown with wire cutter wrapped in a cloth, and pulled with my whole body weight. Came apart in the right place, crown undamaged, tube removed!
Thanks for your help and suggestions.
  • Haha 2
4 hours ago, Barnaby said:
Phew! Done it.
That sounds worse that pulling teeth. And I should know because I'm a dentist! 😂
It's always fun when those weird things you really don't expect to be issues become HUGE issues. Reminds me of a freeze plug in an old decommissioned military truck I once had. One of those nothing jobs that nearly broke me. I still have the ring of shrapnel in a tool box somewhere as a reminder.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
