Hello!
New to the forum, but starting to work to get my grandfather's old Benrus ticking again.
The problem I noticed first, upon being given the watch, is that it will set time just fine, and the date complication works also, when spinning the crown forward. However, it's an automatic, and its hand-winding function isn't working. I.e., the crown will not turn clockwise at all, when it's pushed in. Some contacts on another forum suggested it may be over-wound and bound up, and the mainspring needs to be let out; or perhaps the fork is stuck; or perhaps the balance staff is broken. We shall see.
Today, I removed the crystal (doesn't have a removeable case-back), thinking I'd see some way to remove (what I assume is) a split stem. But there's nothing. The movement tilts out a little bit, but I don't see anything to push or turn or detach or anything. How do I get this movement out of the case?
Thanks in advance!!
Edited by NeithanOfArda
You need to pull hard on the crown to split the stem, there's special tweezers for the job but I'm sure there's other methods.
Just now, NeithanOfArda said:
Wow really? Just pull?
Yes, the stem just locks together.
BUT, before trying it, wait for another member with more experience than me to confirm. I don't want you to damage your watch with bad advice.
1 hour ago, watchweasol said:
Hi  Most front loaders use split stems, there is a presto tool like the hand remover which will induce a straight pull. It needs to be straight and not levered as that's what breaks the stem
Great, thank you! I've got one of those already, so I should be set. Cross my fingers I don't break it. 😉
  • 9 months later...
I have a similar Benrus, and it might have a problem similar to yours. I have just progressed to the point of stem removal and taking the movement out of the case. Did you find the problem with your three-star?
Del
Del
Some Benrus are front loaders. Old mil spec dtu 2ap wore by vietnam soldiers, the battery / mechanical are also front loaders. Post up a photo of the movement so folk here can pass advice
personally I really liked advice pull really really hard who cares the consequence. Normally on split stem's pulling hard would be fine. But there are some split stem's if you pull hard you are going to be looking for replacement components. On these particular split stem this the movement has to slide out in other words you have to somehow rotate the crown with stem to the right position so the movement will just drop out. Yes I know you can't see where that position is but somehow you're supposed to do it. So yes most the time you can pull hard but not all of the time.
Oh interesting. I actually just took apart a very similar Benrus, and I can confirm pulling hard worked, but when I put it back together I'm going to try this.
Edit to note my watch had the exact stem pictured by @Platoabove.
Edited by ManSkirtBrew
For all three styles of Benrus waterproof cases with split stems from the 50's to 70's, the factory service information instructs the watchmaker to carefully use a tweezers to pull out/off the crown and outer segment of the stem. So for this make of watches they are meant to be forcibly pulled apart.
Having said that, nobody enjoys that prospect! As mentioned above, depending on the fit of the movement and dial in the case, it is possible on some Benrus watches to remove the crystal and then find the right orientation so that the stem joint can slide apart laterally allowing the movement to fall out.  Sometimes, even if this sweet spot of alignment can't be found when removing the movement, it can be put in place during reassembly so that at least you don't have to force things back together again. But they can be pushed together again if needed, using what the repair manual calls a "twirling" motion.
Their mil spec watches have the right geometry to allow the slide-and-drop removal, which is why the stock crown will generally have a stamped line on its surface - this "dimple" depicts the orientation and makes it easy to align the stem correctly rather than just trying to find the right spot through blind effort. However, the stem tube on many of the civilian cases extends too far into the case for the joint to be separated in that fashion, so you are left with the (careful) brute force method.
one of the problems with split stem is is ideally we need x-ray eyes. While most of them pull hard they split. then reassembling you just drop the movement and push hard providing are in the right place to snap together. But there are those that that plan doesn't work. Then unfortunately you don't really have a clue of which one you have necessarily.
here's an example of the one that pulling really hard to pushing really hard is not in your best interest
  • 1 year later...
On 11/22/2021 at 1:40 PM, NeithanOfArda said:
Hello!
Thanks in advance!!
NeithanOfArda, did you ever figure out why your Benrus 3021 couldn't be manually wound? I have pretty much the same watch and problem! Was it easy to fix?
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
