Eta 2789-1 amplitude
Gaus
Hello watchlovers, I have a question. I'm servicing an eta 2789-1. When I re-install the balance balance, it runs very nice (260). But when I give the movement a little shake, the amplitude drops enorm. I took out the balanceassembly en re-installed it again. The same problem occured.  What could cause this problem? Problem end stones?
Hello Nucejoe, I found out what the problem was. I cleaned the mainplate with the balance installed, but I forgotten to clean the pivots of the balance staff. After cleaning the problem seemed to be solved.
Thank you for your advice.
with  kind regards, Hans
It also means that you have another problem? You can clean the balance wheel in the watch but you're supposed to remove the balance jewels so they can get clean. The vantage of cleaning with the balance still mounted to the main plate is it protects the balance and hairspring. But as you pointed out if you keep the balance jewels in they don't get clean the pivots and the jewels are not clean either. Not unless you take them out and clean them after the fact. So it's usually better to take the jewels out the first place they can get nice and clean with the exposed pivots also getting clean.
8 hours ago, Gaus said:
I took out the endstones and cleaned them.
Oh wait I didn't read everything you did take the jewels of but it's not just and some is that need the explain the hole jewel needs to get cleaned in other words the entire jewel assembly needs to be cleaned preferably without the pivot being there.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
