Lorus Analogue/Digital copper tail
Hopefully someone can enlighten me?
The image below is from a Lorus with analogue and Digital display that I bought a few months ago. All was good until last week when the analogue hands started losing time. I assumed the battery was in need of changing so replaced both - there is a second battery under the one you can see. Unfortunately the problem persisted.  Lacking any test equipment I did the next best thing and held the watch to my ear. The 'tick' sounded regular until the second hand got to the same section (about 20 seconds) when it was obvious the hand was struggling to move.
After a long head-scratch I noticed the coil of copper that comes from the digital display circuit board (the one just above the battery in the image) and makes contact with the case back. Being loose I removed it and replaced the case back. The watch returned to keeping  perfect time again (for days). Putting the coil back reproduced the problem. It seems the coil is too long and the pressure from the case back is causing the hands (or stem) to bind somewhere. Simple solution was to shorten it. The 'ear' test suggests the issue has largely resolved itself (along with the time-keeping).
What I'm curious about though is what does this coil of wire do? - with or without, the watch functions!
Thanks
PS I should have sent the watch back as it is (was!) still in warranty but where's the fun in that?
Yes he was right. After a bit of tweaking I've now fixed it so the alarm/chime works without putting pressure on the movement below. The watch also keeps time. Not sure why it happened in the first place but it definitely seemed to be longer than it needed to be.
Thanks again.
OMG! You can hear a quartz watch tick? You must be young. I don't think I could hear a quartz watch tick by the age of 30.
Anyway, that little coiled spring is an electrical connection, usually for contacting the piezo sounder on the caseback or sometimes between a upper and lower circuit board.
Edited by HectorLooi
Remove some text
No, not so young unfortunately. I now need glasses to read but for some reason my hearing seems to getting more sensitive!!
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
    • Hello As I am learning, does anyone have any recommendations  on Repair and sourcing in Gold Coast, Qld, Australia ? eg old Seiko coil 4002920 Thanks. Cheers, Ken
    • Is this what all you're looking for?
