I have purchased an invicta model 5103 with a seagull st1902 manual wind chronograph movement (or version of it).
when I reset the chronograph hand, it does not reset back to 12:00, but will constantly move a little further clockwise each time the chronograph is run, stopped and attempted to reset again. Seems like whatever stops the chrono hand at 12:00 is loose and rotates when the function is activated, but im not sure how difficult this would be to fix. Any ideas?
There is a distinct possibility that the hand its self is not very tight on the arbour and slips every time it is returned to the starting point. To check this you will have to remove the movement.   If it has still some warranty from new send it back to be fixed,   otherwise you will invalidate the warranty.
'Whatever stops the hand at 12' is fixed permanently to the second wheel. There are two possibilities (1) as W said - a loose hand or (2) a faulty hammer spring - the part that resets the hand. Definitely send it back.
No warranty, I bought it used. I don’t want to send it back to him, I know he would take it back, but I bought it pretty cheaply. That’s an easy one to check, and a good idea. I hope that’s all it is, because that would not be to hard to seat it a little better. Great idea.
Sounds easy but it's quite a fiddly job to get right even with the right tools... to my knowledge Seagull don't sell parts.
Coming back to this issue; a loose hand usually results on overshoot to beyound the 12 marker. But a fault in the hammer (flyback lever) due to a weak flyback spring , lack of oil on the hammer tips or interference between the hammer and the underside of the second wheel assembly will produce the fault that you describe. Believe me, I have seen this often. A good deal of sleuthing is needed to fix it. But it is an enjoyable occupation. First you should obtain a chronograph guide. They are available on eBay as downloadable pdf files for a few dollars. Search: Esembl-O-Graf Chronograph Watch Course for your movement or something similar.
I will definitely do that. Yes. The hand always moves a little more clockwise every time it’s reset, as of now I just start and stop it to get it back to 12. It’s a fascinating movement and I want to wear it some, but i would probably jump off a bridge if I wore it with that hand not at 12. Lol!
Let’s say I were to send this for servicing. Anybody have a recommendation regarding cost I’d be getting into? I literally got the watch for $53. So I wouldn’t want to put in a pile of money, but if a watchsmith could oil it and service it, and it could fix the issue it may be worth it.
So, my diagnosis just got a lot easier. After starting, stopping, and resetting the chronograph quite a few times to observe the mechanics of the movement, to try to come up with a plan of attack, the chrono hand flew off.
So, while I will have the job of getting the movement out and resetting the chrono hand, at least I know what the issue was, and with all things considered, this is probably the easiest fix. I’ll update you guys once I get around to it, hopefully this weekend. Thank you all!
I had the self same issue with a Tissot, It went back twice under the warranty for them to replace the hand. Third time lucky its been ok since.  I think they change the movement complete.   Always check the simple things first it reduces costly mistakes.
All fixed!  It went pretty smoothly and resets flawlessly now. I’ll be a little busy the rest of the day patting myself on the back. Lol!  Thank you for the help everybody!!
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
