Smiths K7A chime problems
Leffemonster
Hi all, first post on here so please go easy on me! I’m primarily a watch collector/tinkerer and active on Wrist Sushi and The Watch Site. I’ve recently been given a Smiths mantle clock with a K7A movement. I can find very little on the web about them so thought I’d try here. The clock is a Westminster chiming/striking clock, but it only chimes on the hour - nothing on the quarters, and no striking of the hour. I’ve attached an audio file of the chime.
if anyone can offer me any advice on what the issue might be, or if it’s supposed to chime like that, I’d appreciate it. My only experience of clock movements was trying to dismantle a Hermle 340 that ended badly after one of the mainsprings let go when I was trying to wind it down - it destroyed the movement and almost broke my wrist… 😁
Smiths K7A chime.m4a
Smith's 8 day floating balance westminster chime. The chimes sound good and have a good tone. As It is not striking is there power on the strike, is the chime strike silent lever in the correct position (it's the lever at 9 on the dial)  The strike might be caught up somehow and you will need to remove the movement from the the case to check the strike. Do you know how this type of strike/ chime should work?
Both the chime and strike mainsprings were already fully wound and I put about 4 turns on the movement mainspring earlier this week and flicked the balance into life. In the last hour it chimed as per the audio file at 5.15 and struck 4 o’clock. At both 5.30 and just now at 5.45 it repeated the full chime and struck 1 o’clock. And
As you say, it’s a Westminster chime movement but as the audio file demonstrates, it does more than the ‘usual’ Westminster chime would do.
Hi  Unfortuatly there are no picture of the front plate which would be useful as all the control of the chime/strike takes place from the levers on the front plate and the star cam on the center wheel.  The star cam has 4 points on it, one longer than the others this lifts for the hour strike the other three control the quarters and the chime locking cam on the  top right of the front plate controls the duration. Also if the chime/silent lever is at half cock that may cause problems, It is also possible that the pin barrel and drive gears are out of sync. attached two pics of front plates  to illustrate      cheers
Thanks for that. I’ll look to take the movement out at some point and have a look. I know very little about clocks but when I was working on the Hermle that I ruined I remember seeing the rack and snail. I had to return a brand new Hermle movement to Cousins as it only struck ‘1’ no matter what the hour was as there was an issue with either the rack or the snail.
It’s continuing to do the ‘weird’ chime every quarter and strike 1 o’clock. Maybe it’ll sort itself out - it’s been running since the weekend but only recently started striking, so I’ll see what happens. I’ll need to see if I can remove the movement at some point - even though I can’t see the front the mounting points look the same and the chime/silent lever is in that position. Thanks for the photo.
Hi  Old Hippy has provided a strike sequence chart so by moving the hands round the clock you should be able to count the sequence on the chime rods  ie 2314 for the first quarter and so on.    I have some information on the chime/strike on another computer  so will have a look          cheers
I’ve just observed the hammer sequence. On every quarter (now at least), it chimes the 4th quarter followed by the 1st, 2nd and 3rd in sequence, i.e. -
3124 3213 1324 4213 1234 3124 3213 1324 4213 1234
I notice the sequence is different from the table above? I’ve numbered the chime bars as 1 being furthest away in the phot above and 4 the closest.
Edited by Leffemonster
Hi this book contains a lot of useful material apertaining to clocks and watches. chapter 18  ( page 134 for chiming clocks.)
If what you have quoted is one continious chime its not locking and the first quarter is a round of one  round  2nd  is two rounds  3rd is three hour is four followed by the hour strike as per OH's chart
handbook_of_watch_and_clock_repairsa.pdf
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
