From a recent junk watch lot from eBay, I found a ladies Accutron watch. I was expecting a ETA quartz movement inside but to my surprise and delight, it's an actual tuning fork watch.
But my delight quick turned to disappointment when I discovered that someone jammed in a wrong size battery in. The battery is so huge that it has deformed the forks to the maximum limit. I tried prying it out but it's really stuck fast.
Does anyone have the service manual for a ladies Bulova 2210 movement? I have to figure out a way to get the battery out without causing further damage.
Thanks in advance.
I found this on the net. Accutron 2210 uses Maxell 329 SR731SW. I also found many asking for the service manual which many can't find. I haven't found any leads to one, sorry.
Worth just searching for Bulova 221. The zero on the end for 2210 indicates no complications but most references are just to 221.
With that you'll find articles like...
http://mybulova.com/sites/default/files/file/1974_Power_Cell_Replacement_Guide.pdf
https://reference.grail-watch.com/movement/accutron-221
.. which look like they could be handy.
Also Google watchguy bulova 221 which should point you to a Technical Letters reference of interest.
Edited by WatchMaker
Thanks for the effort everyone. Ebay still has parts for the 221 but the prices are crazy. The price for a coil/circuit assembly is more than half the cost of the whole watch.
I managed to pry out the battery after removing some parts. It took quite a bit of effort to get the battery out. The previous repairer must have installed it with a hammer.
The gear train is really weird. It has two worm gears in it. I wonder what the proper lubrication method is.
Anyway, the coils appear okay, measuring about 8K each and the feedback coil around 1K. In place of the usual transistor, capacitor and resistor, there is a black, squarish block with an integral switch sticking out of the bottom.
I powered it up but it doesn't oscillate. I'll check if I missed anything later.
I worked on it a little this afternoon. The circuit is really sneaky. There is a normally closed switch projecting out of the bottom of the IC. If the switch is closed, oscillations are inhibited. So when testing the circuit, if the switch is not wedged open, the oscillations will not start and gives an impression that the circuit is spoilt. I wonder how many good coil assemblies were thrown away because of this design.
The oscillations are very weak and current draw is very high. I'll need to do a thorough cleanup and check it again. I hope the oversized battery didn't damage the tuning fork.
I renamed the file when I went searching for it all I had was a PDF labeled 221.   then it doesn't even start off like one of their normal manuals somebody gives us a bonus page and conveniently skips over the title page.
Accutron 221.pdf
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
