Elephants
RogerH
Morning all,
Just a quickie to tap into everyone's vast knowledge. I have a nice little twin chime mantle clock on the bench which needs a bit of a service and a thorough clean to removed a gallon of oil! There doesn't seem to be any serious problems but I'm curious as to the make - see the pic - can anyone tell me about this movement? it seems well made but I would appreciate any information anyone has.
    • On how many sales Michael ?
    • His feedback is 100%
    • His reply seems quite honest and fair. Whats his feedback like ?, i tend to buy into the seller more than into the sale. Though i do take risks occasionally if i have a gut feeling  i can do ok. Missing and damaged stem can be a red flag but can also mean something quite innocent such as a stem release/set lever screw has come loose and the stem has fallen out and been lost over time. Missing crowns can be less of a problem.  One of first things we do when receiving a watch is to try the wind and set functions and rotate the watch back and forth to see if the secondhand starts up. These are good internal indicators that you may get away with only a service to carry out. Things i personally usually avoid are damaged fancy shaped crystals , heavy case damage, watches with certain damaged/ missing internal parts( parts that can't be self maufactured by the average repairer )The idea is to build up a good stock of commonly comsumable parts, this would be, crystals, balance staffs, watch stems and crowns, springs ( setting and shock ) , watch jewels inc. Caps, impulse and pallet stones, timing washers, all kind of screws.  Those are mostly at beyond a beginner level requirement .
    • We do need more photos but the spacer does seem to be behind the lip.
    • Cant tell if its a lip or a section of thread. If it is lip, then i can only think that the slotted ring is spacer for the armoured crystal to push up to. There isn't much info out there about www crystals. Generally they are popped off with air compression of a sealed case.
