Hello.
Can anyone tell me of best repair shop / parts for this watch? Need gasket for glas, and innerparts    coil block 4002891, clutch wheel 0282890, dato wheel corrector 0982890.
Sorry need more detail such as where you are based/ make of watch etc. Also is is normal for new members to introduce themselves first.
Hi and welcome to the forum   The movement you quote is now obsolete and therefore parts will be at a premium.  Cousins uk  quote a complete movement as an alternative   VD57  for £10 50 complete. So It makes sense to replace the complete movement and scrap the oiginal for parts. The movement is most probably made by Hattori/seiko/epson who are all the same company but different divisions.
Hello everyone.
I am new in this forum, have asked ones for parts for my flightmaster, was adviced to look at VD57 instead of repairing my original watch. Have search around and find no V657-8120 watch or parts on ebay. That makes me more upset to fix my own  one. I have spareparts list and wonder where to order parts broken or missed.
Any good ideas?
BR
ottarno
Hi  According to Cousins uk list all versions of the V657 are obsolete so the alterative is the VD57 or trawl Ebay in the hope of a donor watch or locate second user parts from previously mentioned sources plus speedtimerkollection site  in europe.  Jules borel and esslingers
There is no best or secret place for parts, actually there's s no guarantee one can get parts at all. Have a read to our pinned topic below.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
