Omega Seamaster Chrono Pusher
A friend has given me his Omega Seamaster Chrono case no 176.007 cal 1040 to have a look at .
One of the crono buttons has broken off and will need replacing as the button is missing.
I have looked at Marks video on replacing the pusher in the Omega chronostop thread which looks the same although Mark did a Breitling.
My question is I see Cousins do a Horotec tool for chrono pushers and pendant tubes , does anyone know if there is a cheaper alternative and also whether they would do the job on the Seamaster and if they would do Rolex pendant tubes (looking at doing my Oyster date maybe)?
Bit reluctant to shell out £144 plus vat etc if its no good.
Mark mentions in the vid about using pliers but as it's not my watch I'd rather use the right tool , if it was mine i'd probably have a go.
Thanks Andy
I don't personally like the Horotec set as the ends are quite brittle and can break easily.
These are the ones I use:
https://www.cousinsuk.com/product/chronograph-pusher-tube-fitting-removing
Still quite pricey, but I reckon they are better quality.
I can't be certain but it may be the blue one you need, but please double check the size you need before you order one in case I am wrong.
Brilliant thanks for that Mark , most appreciated
Update on this i've managed to purchase it off the owner , when he found out the price of the parts , so have ordered the bits for myself and the tool Mark recommended ,It's been running and working a treat on the watch winder results are good on the timegrapher so hopefully with a new pusher crystal and caseback seal i will have got myself a keeper :-)
The case has been knocked about a bit but it does date to 1972
Hey Andyclient, I have a Omega Chronostop Genéve with the same missing pusher button. What parts did you order for that - specifically, what pusher button? Thanks!
I got it from Cousins mine was ref:086st0005 which is the complete pusher assembly you will need to put in your case number to be sure though as they might not be the same.
Right before i posted i thought i would check as i have a chrono stop and they are different but Cousins still stock them.
My chronostop case is ref no145.009 which has a smaller pusher than the seamaster , Cousins part no 086ST0002 £42.75 plus vat plus p&p
Andyclient Please for help me, live in Poland, I bought the Omega as a project to revive .Ineed in the two pushers and the crown, you can help in getting parts, numbers ref. or what will fit replacements. For any help I would appreciate and behold my project...
First you need to find out which reference the watch has ? That stands on the inside of the caseback . It looks to be the same as the OP ?
Hi , if the case no is the same as mine a 176.007 then the pushers are 086st0005 and the crown is 43238st but i would check the case no first
cheers Andy
  • 3 months later...
  • 7 years later...
    • Hi All, I'm Geoff and I've been working on/with watches and clocks since I was thirteen. My dad was a watchmaker and while he did not want me in the field as a profession, I've always maintained a pretty good working knowledge. In the '70's I kinda got pulled back into things because Quartz revolution began and he only had limited electronic knowledge. So we combined skills. He the watchmaker and me the electronics tech. Being here in NY helped because we got to know the folks from Bulova, Seiko, Citizen, and WOSIC. H.B. Freid was my Dad's teacher and I was fortunate enough to get to know him too. I still maintain a bench here at home and occasionally work on watches for friends although the hands aren't what they used to be. Not going to be working on any FHF59 or AS1012's any time soon. Oddly enough though my years working with the field taught me how to work on almost anything else mechanical and mostly electronic. Since I was the one in the family who maintained Dad's cleaning and timing machines. those experiences carried over quite nicely into the worlds of recording and audio as well as others. I look forward to the discussions and maybe still learning a trick or two. Cheers to all and nice to be here.
    • The best and almost only way to achieve the magical £ 4.04 individual watch cost is via the loophole ploy of job lot buys Ross. Dividing down the outlay by the number of watches purchased. I've managed it many times in the past, this then gives you the extra edge of choosing any watch from that lot. Maybe we should have an all time winner, whos prepared to troll  through the last four years of posts and pick some worthy contenders. Unfortunately i have a poorly shoulder so i cant raise my right hand and my left shoulder is out in sympathy for my right shoulder. Put your right hand up if you think i talk a load of bull 💩     🖐 Tom's comment is purely restricted to  the Bergeon culture of " lets rip off everyone on the planet " Voted , i thought to keep it in pounds as originally designed and out of respect for Andy . Personally i would have kept the £4.04 as I'm very traditionalist and dont like change but i know how hard you overseas guys are finding it and i believe in fair play. I expect to be posting the occasional Omega or Longines but then you brought this on yourself so dont get jealous Scott 😆
    • Ah but, will you count DIY versions.
    • £10.00 is not a huge amount for a watch these days with the increased asking prices. Let’s count ourselves lucky we don’t have this for tools, it would be £404.00 🤪   Tom
