Waltham service
1 hour ago, PeterS said:
The mainspring has been modified.
the mainspring looks fine. It has a nice taper hopefully it will catch. I really don't like these type of mainspring barrels. At least with the bigger ones you can get in and filed a taper the smaller mainsprings you're almost have to always see if you get a new old stock original spring.
  • 4 months later...
It took me some time to finish this one but I got there.
Quite often you hear, get a pocket watch, they are larger than wristwatches, they are easier to work with.
Yes they are larger and that makes it easier to work with but that’s where it ends. They are old, numerous people would have worked on them, parts would have been replaced with parts that are not quite the same, if you need parts they probably stopped producing them over a hundred years ago, you will need tools, some that are for pocket watches and you can no longer buy them and you will have to hope that some will pop on eBay…
Saying all that, it’s been a very enjoyable project and I learned a lot, far, far more than what you’ll learn when you service a wrist watch that only needs cleaning and lubricating.
I’d recommend picking up a pocket watch, however be prepared to overcome several obstacles.
Enjoy the photos.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
