Waltham service
1 hour ago, PeterS said:
The mainspring has been modified.
the mainspring looks fine. It has a nice taper hopefully it will catch. I really don't like these type of mainspring barrels. At least with the bigger ones you can get in and filed a taper the smaller mainsprings you're almost have to always see if you get a new old stock original spring.
  • 4 months later...
It took me some time to finish this one but I got there.
Quite often you hear, get a pocket watch, they are larger than wristwatches, they are easier to work with.
Yes they are larger and that makes it easier to work with but that’s where it ends. They are old, numerous people would have worked on them, parts would have been replaced with parts that are not quite the same, if you need parts they probably stopped producing them over a hundred years ago, you will need tools, some that are for pocket watches and you can no longer buy them and you will have to hope that some will pop on eBay…
Saying all that, it’s been a very enjoyable project and I learned a lot, far, far more than what you’ll learn when you service a wrist watch that only needs cleaning and lubricating.
I’d recommend picking up a pocket watch, however be prepared to overcome several obstacles.
Enjoy the photos.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
