New To The Site
GCHdesigns
Hello everyone, I'm a Horological student interested in speaking with some watch people.
Was wondering if people would like to see some of the watches I've serviced/been servicing? Would be great to get some feedback and if you know any history behind the company I would love to hear it.
Cheers!
Welcome to the forum,  there are people at all levels on this forum,  from the enthusiastic collector to the master watch guru, Mark, whose site this is.  Whatever your question someone will most likely know the answer and yes I'm sure people would be interested in seeing what you have done.
RogerC
Hi GCH sounds great to me...wish I was in your position but tinkering it'll have to be for me. There is a plethora of knowledge on the site from Mark all the way down to me and lots of interesting characters in between who all have wisdom one way or the other.
BTW Welcome to the talk!
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
