as 1906 auto wind device
Hey
Anyone got any pics on how the innards of the lower and upper bridge for the automatic device should look. I made the mistake of undoing to many screws trying to remove it. (i removed the screw that kept it together as well). And now i have no pics on how it should look. A few pics  below to show what i mean.
as always any pointers are appreciated.
cheers
gary
Hey
Does any one know is there a special way of rebuilding these things.When the 2 springs take up the slack everything just erupts out of place and its start again. I know how they should go in. Just cannoty get them to stay in.
cheers
gary
Gary,
I just reassembled one of these in an AS 2063, and have done several others. I have two similar methods. I first place the bottom plate on either a small anvil or on some flattened Rodico, then put the large wheel thru so it goes into a hole in the anvil or buried into the Rodico. I add the other components so everything is level and all the teeth are engaged in the gears or click. The Rodico helps keep everything together and not able to shift around. I then place the springs into position carefully ensuring again that all the components are level so the spring tension force is horizontal and just holding the components in place. Having everything stuck to the Rodico also helps when adding the top plate so things don't move out of alignment, but if you do it on an anvil instead a tiny piece of Rodico can help keep it from slipping too. I do all the lubrication, including the spring tips, after it's assembled.
Hope this helps.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
