Tag Heuer - rotated dial
Hi. The dial on my wife’s watch has rotated. We have no idea how as she wears it all the time and has not knocked it. We now live in Xiamen and the nearest Tag shop is 1000k away! Is this a common problem and can any watch dealer help?? Many thanks for any good advice.
Edited by JamieXiamen
Add a picture
Welcome to the forum Jamie.
I can't help with your issue as I am pretty new to all of this. Someone will be along eventually that has a fair bit of an idea. I would expect that any accomplished watch repairer should be able to fix it up correctly.
Hi Jamie and welcome to the forum. I am fairly new to this myself but have seen a few postings and replies, your watch is fixable, most likely cause is that the dial feet have broken.
If you look on YouTube Mike has a video of dial feet repair, however, Mike uses a special machine but I do know people have attached new dial feet with apoxy and had very good results.
Good luck, 1000k is a hell of a trip ?
 Hi Jamie,  certainly the dial feet have broken off Cousins uk watch parts have an assortment of feet for re fitting. The fact the watch has a day wheel  adds to the problem of clearance between the dial and the front plate. Most competent watch repair shops should be able to resolder/refit the feet for you . Attachhd are three different types of machine for the job.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
