Worn Pallets
AmBodach
Some time ago I acquired the complete movement out of a Vienna clock.  I got hold of a couple of books to guide me on dismantling, cleaning, etc, and was satisfied that that had been successful in that the mechanism spun round with adequate freedom when re-assembled.  However I ran into the block that the pallets were noticeably worn and I didn't know how to deal with that plus the inevitable of something else coming along that needed attention meant that the whole project got set aside and forgotten about.
So it's about time this was all sorted out.  Firstly, for curiosity why do steel pallets wear and not the brass of the escapement wheel, and then secondly what information should I be collecting to address or replace the pallets?
Rob
I'll just say that brass usually wears hard steel because the brass, over time, picks up contaminants that are abrasive to hard steel and imbed in the brass, so in a clock where at the escapement there is a rapid repetitive cycle the steel, much harder, gets lapped/ground out of spec. To refinish means refacing the pallets while maintaining geometry (easier said than done), of course with a good knowledge of the geometry from various books that spell it out.
A picture would help some of these clocks where fitted with reversible pallets that are ground at both ends so that when the faces ware at one end they can be reversed, having said that you quite often find that the faces on a old clock are worn at both ends because that has already been done.
1 hour ago, AmBodach said:
Thanks guys - I will have a look at trying to organise a photo or two.  I've never photographed anything as small as that before so a bit of trial and error with the camera is going to be involved.
Rob
If you are not equipped for micro-photography, try putting your eye loupe in front of your smartphone's lens.  Really works?
    • Never. Good comment about the DIY thread. Yes I have seen it. Adapted a few thing to make my own systems of cleaning.  Adam and Gentlemen are my 'go to' for inspiration. I only have about 18" by 18" as my working area for cleaning. I have adapted. This is my system.   After disassemble and checking I begin the clean with pegwood and lighter fluid. Fiber brush if needed. Everything , except shellac items, balance bridge and pallet fork, into lighter fluid jar. Large items at base and others into baskets. Jar into ultrasonic warm water. 3 x 2 min. Balance and Pallet in small tray and lighter fluid dripped and allowed to gently clean. All blow dried Everything from jar moved into 2nd jar containing Isopropyl alcohol. Ultrasonic 3 x 2 min.  Balance and pallet dripped with Alcohol for under 1 min. Everything out and placed under nail blower for 10 min. Before assembly I recheck all parts for damage. This is when I make my decision to order parts as I can see what needs to be done. My system in now pretty good. Well, at least for an amateur.
    • Looks good, maybe a little complicated to put together. So certainly some effort, time and headscratching involved if you're not particularly tech savvy. Personally i like the more simple approach of diy cobbling, you dont end up with anything automated so the cleaning operation is a bit more hands on. But you have something simple, cheap, less to go wrong , easy to fix if it does, but in essence cleans just as well. Look at the diy watch cleaning thread Ross, there are some simple ideas in there if you feel you want to make something.
    • So you need a 3d printer in order to have this. I wonder is the other parts that you need are available say in the UK because that is where I live. It looks a nice cleaning machine.
    • The case style and the movement are in the style of American. If you take it apart you will need mainspring clamps as the springs are strong and very long
    • Lol!  Not even close! 😆  It's a Sam Hueng movement.  A Korean firm.  So I think this is post-war, 1940-1960?  Maybe pre-Korean war since it doesn't say "South Korea?"  The chime side winds clockwise, but the power side winds counter-clockwise.  Looks like someone has been trying to wind the power side clockwise for who knows how many years and the spring was been unwound to the state you see in the pictures.  It doesn't seem damaged though, and I was able to wind it in the correct direction.
